Results 1 to 10 of 11
Thread: heater not working
    Regular Member Dan.'s Avatar
    milton keynes
    Default heater not working
    Well the gsi has yet another problem, now the heater has packed up, funny smell in and out of the car, and the blowers dont work altho i can hear the motor or fan slightly when i turn the heater dial, with this aswell as the cim packing up im feeling like getting rid seems to be one thing after another . Anyone wanna buy a gsi lol
    milton keynes
    anyone know what might be the problem with the heaters?
    Aug 2010
    Leeds
    Id take a guess at the resistor pack has burnt out and thats your smell plus not working, there is a guide on here to fix a very cheap fix if you can solder.
    I beleive it's behind the glove box which you may have to remove.
    May 2006
    scotland
    From memory if the resistor pack packs up then you will still be able to use the heater fan on full speed, it is just the lower speeds that do not work. Is there a fuse you can buzz out for the heater fan?
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 138000
    as said above does heater number 4 still work ?
    heater number 4 has nothing to do with the resistor pack
    the prevoius owner may have had a leak through the pollen filler causing water to go into your heater blower this drys the grease inside the blower causing it the squeak
    milton keynes
    no doesnt work on number 4 at all, ill check the scuttle tray and see if the pollen filter is wet? whereabouts is the fuse for the heater?
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 138000
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 138000
    milton keynes
    cheers fella ill have to have a poke around tomorrow
    Apr 2012
    cambs
    Default blower siezed
    i had the same problem.
    water had blocked the drain bung below the pollen filter so i unblocked that and pulled the filter out to gain access to the top of the motor.
    with the ignition OFF (obviously) i squirted wd40 into the top of the blower and kept turning the blower drum by hand a few times. i turned the ignition on and tried it, if it didnt work, ignition off. after a few goes it freed itself and spun up and has been ok since.
    i didnt need to dis-assemble the glove box and motor at all.
  1. HELP! Heater not working
    By vectrasri-j in forum Bodywork & Interior
    Last Post: 25th November 2017, 10:15
  2. Heater Not Working
    By Knight Rider in forum Electrical & ICE (including SatNav)
    Last Post: 5th July 2012, 09:22
  3. Heater not working
    By Shadrack in forum Engine & Drivetrain
    Last Post: 25th February 2012, 19:54
  4. Heater not working..HELP!!
    By princess09 in forum Vectra C / Signum Car Chat
    Last Post: 13th October 2010, 08:27
  5. Heater no Working, no hot air Help Please!
    By darkstar32 in forum Electrical & ICE (including SatNav)
    Last Post: 6th June 2009, 16:04
vectra c heater not working at all
