Thread: MKI9200 - Sound Quality
    Regular Member dexter69's Avatar
    Apr 2012
    Stirling
    Default MKI9200 - Sound Quality
    I decided to install the mki9200 yesterday, and after a hiccup with Nexus pairing, finally got it working and it's one seriously cool bit of kit.
    However, I've noticed the bass doesn't really cut it, presumably down to the bluebox not being able to cope, so I'm wondering if there's anything I can do to improve sound quality ?
    I've got a CDC40 dab HU, so I think I'm out of luck with Line In to it - is there any other reasonably cheap and easy way to improve sound ?
    Cheers !
    Regular Member mat_splat's Avatar
    May 2012
    Frimley
    There is a "virtual super bass effect" in settings. It shifts the eq. I have the MKI9000 which is the same blue box and have been looking at ways to wire it into a sub. The only real option is to get an amp with a high-level input and take a line from one of the rear speakers. Bass is mono anyway so it won't matter which.
    The only problem is that the canbus may detect a change in impedience, it does this to stop speakers blowing, but I have not tested it yet.
    Apr 2012
    Stirling
    Yep - I've managed to suss out I can improve bass by dropping the VSB to the lowest frequency, but it's still a little tinny (but not unacceptable)...
    Top end is brilliant, but when you're listening to dance music, I could do with some more bass...
    May 2012
    Frimley
    Sub it is then mate. You will have to get a High Input amp and go from there.
    Realistically, you should upgrade the whole system i.e. front amp, reap amp and sub amp but that's a bit heavy going for phone calls from a screaming wife...
    quick question
    i have the mki9100 , it has the smaller screen than the mki9200 , is it possible to get a screen for the mki9200 and plug it into existing system
    i see on the blue box there is the plug for it so just wondered if it was just an add on
    Regular Member Angel1368's Avatar
    Mar 2012
    liverpool
    13 Post(s)
    Trim : VXR
    Engine : 2.8 V6 turbo
    Mileage : 44,000
    Quote Originally Posted by marktaylor View Post
    quick question
    i was thinking the exact same mark
    May 2012
    Frimley
    in a word, no. The software on the box is for each individual version.
    Perhaps you could flash it, but im not sure that would work. Especially as most of the time the update process doesn't even work.
  1. Anyone near me able to help. (Parrot mki9200)
    By SEANYboi in forum Electrical & ICE (including SatNav)
    Last Post: 25th February 2013, 20:59
  2. For Sale: Parrot MKi9200 Car Kit
    By AntSSSS in forum General items for sale
    Last Post: 25th January 2013, 21:25
  3. Parrot mki9200
    By blackviper90210 in forum Electrical & ICE (including SatNav)
    Last Post: 21st January 2013, 10:02
  4. Parrot mki9200
    By stanlee in forum Electrical & ICE (including SatNav)
    Last Post: 2nd November 2012, 20:51
  5. xtrons sound quality
    By J P S in forum Electrical & ICE (including SatNav)
    Last Post: 12th April 2012, 08:09
