Results 1 to 10 of 14
Thread: Not a good day
    Regular Member pipamish's Avatar
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Unhappy Not a good day
    Not a good day i knew i had a slow puncture the other day and i have been worried about a cracked rim well i took the car to kwik fit today for them to check it out and to my horror the tyres have worn badly on the inside edge so i have not only had to replace the punctured tyre but i have had to have 2 tyre's.
    Ok i have had to have 3 tyre's so i said to the chap fit the 2 and i will have the other 2 end of the month as i came out £400 lghter. Im gutted tbh as i was planning on my suspension this month just means im going to have to wait a bit longer.
    On another note i won't be having Khumo's again thats for sure and a positive note it drives and grips so much better now i have tread
    Feb 2012
    West Midlands
    Hi pipamish read your recent thread on vxr-ing your car, it looks gr8 , did you order the complete vxr bumper using big pete thread for part numbers or did just go into vx dealer and get them to do it ? and if so how much did it cost.
    I need to know how much I need to save
    Any advicse much appreciated
    Regular Member tangoman's Avatar
    Berinsfield,Oxford
    Vehicle : VXR Estate
    Trim : VXR
    Engine : 2800
    Mileage : 3000
    worn tyres on the back or front. Either way I would suggest a tracking/alignment check.
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Quote Originally Posted by tangoman View Post
    It was the rears bud im booking myself in at hi q to have a full allignment done
    Northampton
    Engine : A20DTH
    Mileage : 88000
    If the tyres have worn out on the inside edge it is nothing to do with the tyres but alignment issues. Where the tyres on the front or rear?
    Which tyres did you get from Kwikfit?
    Berinsfield,Oxford
    Trim : VXR
    Engine : 2800
    Mileage : 3000
    Check the upper control arms for wear first.
    Jack up the rear of the car and wobble the top and bottom of the wheel. Any movement may need new Banana arms.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    If its the rears it suggests that the rear trailing arms are worn and the tyres are going outwards at the bottom. Before you get an alignment check you need to new trailing arms fitted, if you don't then your new tyres are going to wear on the inside as well.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    This is how you check the rear suspension arms. Do not jack up the car to check as this is not the correct way to do it!
    And yes I do look fat in the video!
    [ame="http://www.youtube.com/watch?v=h-LF-qQY-Lc"]How to check the rear suspension arms on a Vectra C - YouTube[/ame]
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Quote Originally Posted by merikiito View Post
    Yeah i did this already i had no movement whatsoever i do have my arb bushes and stuff to fit so i get it all checked by hi q.
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    I had to have the ones they had at the time they were dunlop sport maxx
  1. Maybe Good Things Do Happen To Good People....
    By Leemarksmith in forum General Chat
    Last Post: 16th October 2010, 22:12
  2. Cheap rear spoiler...too good to be any good?!
    By Lightboy in forum Styling
    Last Post: 26th February 2010, 23:03
  3. seems a good set up for a good price?
    By david.aka.judas in forum Vectra C / Signum Car Chat
    Last Post: 19th January 2009, 09:31
  4. Some good news, and some not so good...
    By Penfold101 in forum The 'Off Topic' room
    Last Post: 19th August 2008, 10:06
  5. Good spec Signum, Good price too!
    By AndrewTi in forum Vectra C / Signum Car Chat
    Last Post: 18th April 2007, 18:44
