Thread: Help!! Dreaded fuel pressure problem
    Perth
    Default Help!! Dreaded fuel pressure problem
    I've got a z28net engine throwing up p0190. Does anyone know what voltage the fuel pressure regulator should read at idle?
    Regular Member dbgb25's Avatar
    Aug 2009
    Margate kent
    got same code just on 1.9 cdti
    Aug 2009
    Margate kent
    rail presure control valve around 3.6 Ohms
    Perth
    Thanks, been a bit of a guessing game so far
    Regular Member viper8's Avatar
    Mar 2011
    Northamptonshire
    Piriemr
    did you ever get this problem sorted ?
    have 2 codes which are roughly the same problem as yours
    P0090 fuel pressure regulator control circuit
    P0170 fuel trim malfunction
    car starts crap when cold sometimes stalls
    runs perfect after that
    but judders when i put my foot down
    do you have the same problem ?
    Aug 2010
    south northamptonshire
    i had this problem on my 1.9cdti 16v, it also kept cutting out every now and then, as well turnt out to be the fuel pressure regulator plug, which id advise a scrappy as vauxhall will only supply a lume at over £300 :0
  1. Anyone with a Z22YH .. NOT had the Fuel Pressure problem?
    By ShamusUK in forum Vectra C / Signum Car Chat
    Last Post: 4th October 2010, 14:30
  2. Insignia low fuel pressure - common problem
    By graded-appliances in forum Insignia car chat
    Last Post: 1st June 2010, 13:14
  3. fuel pressure problem
    By officerbel in forum Engine & Drivetrain
    Last Post: 2nd January 2010, 11:18
  4. Tonight on BBC's Watchdog - Vauxhall fuel pressure regulator problem
    By happychappy in forum Vectra C / Signum Car Chat
    Last Post: 5th August 2009, 18:53
  5. H.p fuel pump pressure regulator problem 2.2 direct
    By Dobs in forum Engine & Drivetrain
    Last Post: 3rd August 2009, 18:06
z28net fuel pressure
z28net normal fuel pressure
