seen a set of 18s on gumtree, will these fit, they mite be 112 offset if so will i get away with wobble bolts, http://www.gumtree.com/p/cars-vans-m...ry-item-full-2
anyone can save me a trip to see them, anyone seen them on a vectra they came of a honda accord, with 114 offset with wobble bolts, it must leave them being 112 offset, could i go the down to 110 with wobble bolts.
Never heard of Honda fitting, google the bore size of the car there off...
no, i think you can only adjust from 5x110 too 5x112 with wobble bots
honda bore zide 64 vectra 65 so mit not fit good site for bore sizes http://lincsdriver.com/index.php?opt...rces&Itemid=16
dont know if theirs any cheaper way but the only thing i can think of doing is
to buy some Hub Adaptors/spacers so it will be like a 20mm spacer that bolts on to your normal 110pcd vauxhall hubs then the holes on the spacers will have a 114pcd to fit the honda wheels.
but by the time you have paid out the £300+ for these adapters you might as well get a good set of vauxhall alloys or aftermarket ones
i have 19 snowflakes on, like to change to 18s, 19s a bit to hard a ride for me and 18s is cheaper to put tyres on.
Look at some of the Saab and Alfa fitment alloys, there 110 PCD and same bore size...
Think Alfa offset is only couple mm off vectra/saab also, I've seen some nice Alfa 19's I fancy, look like they belong in an insignia
These are the ones I like...
eBay item: 280709315797
Can't post link, on mobile.
