Thread: Drivers Side Electrical Problem + Stereo
    Apr 2012
    Default Drivers Side Electrical Problem + Stereo
    Hi guys, wondering if anyone can help with my problem
    I bought a '03 Vectra C 2.2 LS and it has a few slight problems, but the one I'd like to get sorted would be the drivers side electrics.
    The drivers window, side mirror and central locking do not work.
    The window & side mirror controller works for the passenger side OK, so I am thinking it could be earth related.
    Also the stereo doesn't work (CDR 2005 looks totally broke), and I have looked around for a 2 DIN to single DIN adapter but I can only see 1 place that sells them, do you guys have a suggested retailer for these?
    Any suggestions or help?
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    First thing I'd be checking with the door is the multi plug that connects the door to the car and then the connection onto the door module as it sounds like everything has died and that's all they have in common unless the door module is knackered.
    Edit: just re-read it and you're saying the passenger side works from the drivers switch if I've read that right in which case it's almost definitely the drivers door module.
    As for radio adaptor try here http://www.caraudiodirect.co.uk/inst...uxhall-vectra/
    Apr 2012
    Wow quick reply, and thanks.
    Quick question about location for drivers door module, where is it?
    Not got Haynes book yet
    Also thanks for the link for the facia adapter, actually the place I noticed.
    Ely, Cambridgeshire
    61 Post(s)
    Year : 2010
    Door modules are attached to the doors under the panels. Check the connection to it is good. Otherwise it's possible a previous owner has replaced it and not tech 2'd it in or just that the one on there has gone faulty.
    Apr 2012
    Thanks Ian, I'll check and report back
  1. Wiper Electrical Problem? (Not sticking or cold weather problem)
  2. Drivers side door problem
    By midge in forum Electrical & ICE (including SatNav)
    Last Post: 15th January 2012, 16:09
  3. Electrical problem
    By damm in forum Electrical & ICE (including SatNav)
    Last Post: 27th December 2010, 11:57
  4. drivers side window problem
    By kgsric in forum Electrical & ICE (including SatNav)
    Last Post: 20th December 2006, 08:37
