Thread: Light fault dash but why???
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Default Light fault dash but why???
    I had rear bulbs replaced, all working now after the dash light came on, but after fitting replacement bulbs and all working right, why is the light bulb with "!" inside still stays on? What else does it do apart from bulb fault?
    Confused!! :-/
    Regular Member gsi-robster's Avatar
    Mar 2012
    paisley
    just a guess and a couple of suggestions mate
    think it constantly checks the line resistance cause mine sometimes comes on whilst driving without going anywhere near the brake.
    correct wattage of bulbs fitted i take it?
    check all connections to light units / rear electrical control area and fuses/ bulb holders for corrosion and poor contact.
    ive still to do mine as my brake light function can not be faulted and display warning rarely comes on.
    dont know if fault needs cleared from car modules but i wouldnt have thought so
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    I've cleared fault codes, it now comes up reverse left light malfunction, but showing up, I'll check again I might have not fitted it properly.
    I got 100w bulbs for low beam cos it's not very bright, passed on the computer, only showing rear fault. Getting fed up of the orange light error on dash lol
    11 Post(s)
    Quote Originally Posted by Humourbash View Post
    Be careful you don't burn out the wires, relay, as you're drawing twice the current they were designed for, Also watch you don't melt the reflectors in the headlights.
    Engine : 1.9 CDTi
    Have you changed the bulb its telling you that has a problem?
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Yes I found burnt out bulb so replaced that, while I was at it I checked every bulb to see how it is all fine
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    When I changed setting to xenon for headlight, it changed nothing, so might be dirty lens? Anyways, back to topic lol
    Regular Member stevedee's Avatar
    keighley
    Mine has fault light that says passenger parking light fault but all the bulbs are working fine on both sides ???
    any ideas out there
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    When u put sidelight on and keys removed, does any stay on? Back to my topic please as you're hijacking my topic!
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Fixed!
    What I did was checked every bulbs, and the holders. Making sure it touching best consult to electrics, all working now and light exclamation mark on dash gone now
    Only to solve one more, that the heater not working right!
    Admin, can u close this? Thanks everyone for helping me. ;-)
  1. Intemittent Dash fault
    By kim9274 in forum Electrical & ICE (including SatNav)
    Last Post: 6th October 2011, 13:47
  2. strange dash electrical fault
    By lee866 in forum Electrical & ICE (including SatNav)
    Last Post: 29th June 2010, 17:56
  3. Fault: Spanner with car on dash
    By dolf.peeters in forum Vectra C / Signum Car Chat
    Last Post: 22nd June 2010, 21:04
  4. dash intermittent fault
    By winnie2457 in forum Electrical & ICE (including SatNav)
    Last Post: 11th March 2010, 01:04
  5. 3rd Party Radio Causing Dash Fault?
    By akulla in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd July 2008, 23:37
