Results 1 to 10 of 16
Thread: hhmmm....think the car has been leaking
    Regular Member krazylegz's Avatar
    South Shields
    Eek hhmmm....think the car has been leaking
    The vectra hasn't been used for a few days as I've been using the mondeo, reached behind the passenger seat to pick up something and was shocked to discover this......
    Lifted the scuttle panel and sure enough it was full of water, so poked the sh**e out of the drain, put in a new pollen filter and took off the motor to clean it out, got the surface water up with a sponge but the carpet is still dripping wet
    Regular Member Ben_'s Avatar
    Audiville, WM
    had exactly the same problem at weekend mate, try running a container into the carpet. The force of it should bring more water to the surface to collect then just put foot blowers on it when driving.
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    4+ A/C + hot = I had something similar in the boot of the Siggy, due to the fact that i'd not put the seal back on the rear light cluster when i took them off to clean them
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Newspapers and a heavy weight to help soak it up, unless you can borrow a Vax, or similar, from someone. BTW get back into the scuttle and take that rubber bung thing out, it wont get blocked up again.
    Regular Member borderlinechris's Avatar
    Jan 2012
    scotland/england border
    or cut the top of a long necked drinks bottle and shove it up the rubber bung
    Regular Member tangoman's Avatar
    Berinsfield,Oxford
    Vehicle : VXR Estate
    Trim : VXR
    Engine : 2800
    Mileage : 3000
    Best thing i found is to remove the bung from the scuttle, cut it in half so th bottom hole is not so big then refit.
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    remove it completely.. Its a poor design as the water has to rise to get over the rubber lip.
    Slough
    74 Post(s)
    Vehicle : insignia vxr
    Trim : vxr
    Engine : 2.8 turbo
    Year : 61
    Mileage : 38000
    Quote Originally Posted by krazylegz View Post
    mate im in slough so not to far away , got a vax here so could get that and the rest off the carpets cleaned at the same time , this would be free off course just need to come here , take half hour , to do . khalid
    the vectra has gone , but not far away so ill still see it form time to time
    Full Member spennny's Avatar
    Blantyre
    I am in Farnborough with an upright carpet shampooer , it's a brilliant piece of kit if you need to use it , comes with hand tools also
    Sent from my iPhone 4s using Forum Runner
    Regular Member skidmark1's Avatar
    Sep 2010
    cornwall
    Vehicle : 2.2 Direct
    Trim : SRI
    Engine : YH 2.2 petrol
    Mileage : 85000
    Quote Originally Posted by happypostie View Post
    Quote Originally Posted by spennny View Post
    What a lovley bunch of helpfull people there is on here, I wish I lived further up country I would buy you all a pint
  1. I am leaking
    By KevinG in forum Engine & Drivetrain
    Last Post: 19th February 2011, 21:29
  2. oil leaking...
    By danman487 in forum Engine & Drivetrain
    Last Post: 6th September 2010, 08:01
  3. Rad leaking
    By VECTRAMAN in forum Vectra C / Signum Car Chat
    Last Post: 27th August 2010, 20:16
  4. air con leaking
    By nicademus in forum Bodywork & Interior
    Last Post: 7th July 2010, 22:11
  5. leaking air con
    By baz2003uk in forum Engine & Drivetrain
    Last Post: 19th June 2010, 23:38
