Thread: Poor Starting
    Apr 2012
    my house
    Default Poor Starting
    Hi all, I have bought a 2.0 dti vectra on an 03 plate at the weekend and its been a b*tch to start from cold. Mornings or if left more than 6-8 hours. Service history says starter was replaced last year but may have been a afailed attempt to fix this.
    This morning it was smoking from exhaust while trying to start and fine after it started, runs great once going and fine to start for few hours after. 1st attempt each time.
    Thermostat is stuck open so ordered one of them along with temp sensor,
    So:
    1. Any idea about poor starting?
    2. Is this correct thermostat for my engine http://www.ebay.co.uk/itm/1107443752...84.m1497.l2649 says vectra B but another website says my engine code is y20dth
    3. Does this car have a dpf?
    Nov 2011
    Cheshire
    Vehicle : 1.9CDTi(120)SRi
    Engine : 1.9DT
    Mileage : 100k
    Split or perished leak off pipes or worst case injectors seals are leaking, it allows fuel to drain back to the tank over a period of time causing the poor starting.
    Apr 2012
    my house
    Which pipes are common to go on these and can you buy injectors seals without the injector?
    Don't fancy paying to replace the injectors
    Apr 2012
    my house
    ok, been reading about the leaking injector seals a bit more.
    Is i not possible to remove the injectors without removing the camshaft? I don't fully understand why it has to. I've only worked on petrol engines before and cud just pop injectors out
  1. poor starting
    By tomo610 in forum Engine & Drivetrain
    Last Post: 15th January 2012, 19:21
  2. poor starting
    By kmx racer in forum Engine & Drivetrain
    Last Post: 26th July 2011, 22:51
  3. Poor starting
    By Croxley in forum Engine & Drivetrain
    Last Post: 23rd March 2011, 20:25
  4. EGR and poor starting
    By dhwigston in forum Engine & Drivetrain
    Last Post: 23rd January 2010, 22:07
  5. poor starting
    By m1ke823146 in forum Engine & Drivetrain
    Last Post: 2nd November 2009, 12:14
