Thread: Brake Light Problem
    Regular Member Bethan39's Avatar
    South Wales
    Default Brake Light Problem
    Can anyone shed some light on my problem? my brake lights seem to have a mind of there own, sometimes they come on when you press the brake pedal and go off straight away after you take your foot off the pedal and then sometime they take a few seconds to go off then other times they are on for a good 30 seconds or so. Ive changed the brake light switch that seemed to work for a while but the problem has returned again! i'm considering taking the battery off for 30 mins to see if a reset will sort it. I'm getting paranoid now keep looking in the rear view mirror at traffic lights
    11 Post(s)
    Replacement switch also faulty?
    Engine : 1.9 CDTi
    Did you set the brake light switch when you fitted it?
    South Wales
    Quote Originally Posted by lee gsi View Post
    No mate i didn't know you had too?
    South Wales
    Quote Originally Posted by Bethan39 View Post
    Does anyone know how to set the switch
    Engine : 1.9 CDTi
    You pull the plunger out (So it gets longer) fit it inplace then when you release the brake peddle it sets the length.
    South Wales
    Cheers Lee i take it i can still do it with the new switch in place by pressing the brake pedal down and pulling the plunger out fully? don't really want to remove the new one as i broke the old one through impatience
    Regular Member gsi-robster's Avatar
    Mar 2012
    paisley
    does your car have hill hold function?
    had this in my last transit and was a pita cause i didnt know what it was
    South Wales
    Quote Originally Posted by gsi-robster View Post
    No mate normal handbrake
    Engine : 1.9 CDTi
    You should be able too but they are quite tight.
    Try extending the old one so you can see what its like.
  1. Brake and Side Light Problem
    By itdaveh in forum Electrical & ICE (including SatNav)
    Last Post: 1st October 2012, 22:51
  2. Brake light Problem
    By DavyC in forum Electrical & ICE (including SatNav)
    Last Post: 31st July 2010, 18:29
  3. rear brake light problem, bulb ok, please help
    By circushead in forum Electrical & ICE (including SatNav)
    Last Post: 14th May 2009, 18:29
  4. Brake light problem
    By dave200 in forum Electrical & ICE (including SatNav)
    Last Post: 25th February 2009, 01:46
  5. Brake light problem?
    By caravaner-tony in forum Vectra C / Signum Car Chat
    Last Post: 11th February 2008, 10:08
