Thread: Clutch Bleed
    Regular Member mat_splat's Avatar
    May 2012
    Frimley
    Default Clutch Bleed
    So about every 4-6 weeks my clutch fluid drops to a low point and I lose the pedal...
    I have been topping up and bleeding to try and save the cost of new slave/master/clutch kit.
    However, in my travels I have been to Drive Vauxhall in Aldershot to price parts up, (mostly worried about DMF cost) They looked up my car, looked up the part, checked it on the shelf and its a standard fly wheel, listed as DMF.
    Hooray for that, at least I can get it skimmed and save £300 on the job.
    Any body else found this on the Z18XER?
    Barrow In Furness, Cumbria
    The Z18XER doesn't have a DMF. Only diesels / higher powered cars have it. The 1.8 petrols have a normal clutch.
    My car doesn't have any of the above problems.
    Dec 2011
    Seaham
    Have you checked the master for leaks or is it simply coming out of the slave?
    Regular Member gsi-robster's Avatar
    Mar 2012
    paisley
    if no visible leaks around master cylinder/ combined res / master to re hose / master attachment housing and pipe / pipe to flexi / flexi to slave pipe in bellhousing.
    couple of wee seals connecting each part
    then id say its your csc quite common i found out after having the same woes
  1. How to vacuum bleed clutch?
    By Richard.roberts in forum Engine & Drivetrain
    Last Post: 28th November 2012, 22:31
  2. Clutch bleed nipple
    By Imraldis in forum Vectra C / Signum Car Chat
    Last Post: 9th October 2012, 21:19
  3. how to bleed the clutch
    By vectra3.2dave in forum Vectra C / Signum Car Chat
    Last Post: 30th May 2010, 14:26
  4. Clutch bleed problem
    By Gazza36 in forum Engine & Drivetrain
    Last Post: 24th February 2010, 20:48
  5. Brake and Clutch bleed
    By GoldenWonder in forum Suspension, Wheels & Brakes
    Last Post: 11th September 2008, 20:21
