Thread: Noise when cruising ~60mph+
    Regular Member Coxy's Avatar
    Apr 2012
    Hants, UK
    Default Noise when cruising ~60mph+
    Hi all,
    Sorry if this has been covered before but a search didn't throw up anything that sounded quite the same. First off, my car - it's a 58-plate Vectra SRi 1.9CDTi (150) hatchback, with no mods and about 59k on the clock.
    Now my problem (if it actually is a problem!). When cruising at around 60mph and above in 5th/6th gear, there's a noise in the background. It's not particularly loud, but if you have the radio off - or just down low because SWMBO wants a sleep - then you'll notice it. Whether it occurs at slower speeds or not I can't say for certain, but I've only heard it when cruising along on the dual carriageway/motorway.
    Basically it's a kind of 'droning' noise, about 2secs in duration, broken by gaps of around 1-2secs. All very consistent. It doesn't seem to vibrate the car, revs don't drop/increase and there's no noticeable affect on performance. Just the drone, droning on and off, on and off, on and off - you get the picture.
    Any more help you might need to help diagnose then just ask and I'll do my best to help.
    Many thanks in advance,
    Coxy
    Dec 2011
    Seaham
    Think that could be your tyres, what tyres have you got on and how much tread is left on them?
    Apr 2012
    Hants, UK
    Hi, thanks for the quick reply. The tyres are as per what the previous owner had fitted (only got car couple of weeks ago) and all have well above the limit, not far off being new. They are as follows:-
    215/50z R17 91w
    Front - Avon ZV5
    Rear - Radial MA-V1 Maxis
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Swap front to back, and youll probably find it the cheap rear tyres
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 141000
    i had the same problem it was my 2 back tyres
    i brought 2 goodyear excellence tyres dronning noise gone as like in the poll below
    some times its related to the tread if its to low or if its cheap tyres and down to certain brands
    http://www.vectra-c.com/forum/showth...light=dronning
    Regular Member shinyb1's Avatar
    Jul 2011
    wigan
    wifes beemer does it , cheap tyres in my case because of the size .
    Apr 2012
    Hants, UK
    Thanks for all your help guys, was worried there was something going wrong after just a fortnight of ownership!
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    Try altering the tyre pressures and see if it makes a difference, at least for a short while.
    You can run with higher tyre pressures, the owners manual says you can raise the tyre pressures to save fuel.
    However the wheels at 60mph are going round a couple of times per second, and you have gaps in the sound.
    So the noise might still be the wheel bearing/hub assemblies.
    In my case the rub - rub - rub noise was rear wheel bearing/hub on the passenger side. I changed both sides at a cost of about £85 for parts.
    I even bought some used wheels and tyres, changed them myself and the noise was still there. Most annoying.
    The only real way to check is to get a passenger to sit in the front and rear seats and try and narrow the noise down to the front or back, and then maybe to the left or right.
    Then you need to remove the wheels and brake calipers and turn the hub assembly and hear/feel it.
  1. No Intermittent Wipers Until 60mph!
    By cold-chilli in forum Vectra C / Signum Car Chat
    Last Post: 31st May 2011, 21:37
  2. 0-60mph 6.2 secs
    By vectradmr in forum Diesel Engine related
    Last Post: 18th March 2010, 10:18
  3. 0-60mph or 0-62mph runs
    By Celes in forum Vectra C / Signum Car Chat
    Last Post: 13th July 2009, 11:26
  4. This is what the wife was cruising in on Sunday
    By Ste in forum Vectra C / Signum Car Chat
    Last Post: 29th November 2007, 23:00
  5. Cruising Estate
    By MJED in forum Vectra C / Signum Car Chat
    Last Post: 19th July 2005, 18:24
