Results 1 to 10 of 15
Thread: another spring question, but a bit different
    Events Manager & Moderator jon1.9cdti's Avatar
    Swanley , Kent
    88 Post(s)
    Vehicle : Sports Tourer
    Engine : A20DTH
    Year : 2010
    Mileage : 201000
    Default another spring question, but a bit different
    recently my front springs snapped and have never been happy with how the car has sat since,
    according to vaux my vec sri 1.9 cdti has the lowered sports chassis, and they qouted part number 93190523
    after visiting PLASMA a few weeks ago, FLOB measured and the car is sitting 30mm too high at the front and the rear sits a little low and i believe the rear has soft springs as it had new shocks last year
    now the question
    if i get lowering springs for a normal spec vec c will it then make mine sit where it would if the suspension was correct?, ie springs for a normal vec that lowers it 30 mm would it make mine sit correct
    Swanley , Kent
    88 Post(s)
    Engine : A20DTH
    Year : 2010
    Mileage : 201000
    a standard sri is 15mm lower than a standard ls etc,
    how much lower is a sports lowered chassis than a standard sri?
    Dec 2011
    Seaham
    I think the SRi dictates the lowered sports chassis, which is 15mm lower then standard.
    I dont think yours would be lowere as standard then a standard SRi.
    Your springs will need to settle and the rear ones could be knackered, how old is the car? What is its history?
    Swanley , Kent
    88 Post(s)
    Engine : A20DTH
    Year : 2010
    Mileage : 201000
    Quote Originally Posted by Ben50n View Post
    So I'm led to believe by vauxhall there is the standard Sri springs (sports chassis ) and the lowered sports chassis springs so there must be a difference surely ?
    I have done 1000 miles since fitting the new springs and should of settled by now and even so they won't settle by 30mm , the car started out as a reps car for carlsberg and as such has probably had quite a few cases of lager in it over the years hence the soft rear springs ,
    As far as I am aware there are only two versions of each spring :
    standard
    lowered (often called sports)
    The only other engine that has a further version, from OE parts, is the 3.2 as the VXR has a further version available
    If the dealership has searched by registration and/or chassis number they may have supplied the wrong part numbers
    I often have this with my vehicle, as it comes up as a 3.0 V6 CDTI Elite, but some parts also come up as a 1.9 CDTI (such as the brakes)
    Swanley , Kent
    88 Post(s)
    Engine : A20DTH
    Year : 2010
    Mileage : 201000
    standard
    when the dealership searched by reg and chassis number nothing came up for suspension so they had to look through pages and pages before they could find correct part number
    PRESTON
    If the dealership searches on EPC with your reg and they look on the VIN decode section, that is where it will tell them if the car has the sports lowered chassis, which as i understand it all SRI's have as standard. I will have a look at the part number you quoted on EPC at work tomorrow and see what they are listed for.
    PRESTON
    Had look at EPC today and discovered the following. It would appear that Vauxhall list three suspension setups for Vectra and Signum.
    Standard chassis, standard ride height with standard shock absorbers, 6 different part numbers for front springs depending on year and transmission fitted.
    Sports chassis, standard ride height with uprated springs and shock absorbers, front spring part number 93190526, production option code XJ1. I believe this might be used with IDS.
    Lowered sports chassis, lowered ride height with uprated springs and shock absorbers, front spring part number 93190523, production option code of XJ2.
    Sadly it doesn't mention what the ride height measurements are, but entering your reg number in EPC, it will tell you what option code your car left the factory with.
    Admin plasma's Avatar
    On the Forum
    265 Post(s)
    Engine : 150
    Mileage : 74000
    pm me reg no. pls Jon
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Swanley , Kent
    88 Post(s)
    Engine : A20DTH
    Year : 2010
    Mileage : 201000
    Quote Originally Posted by plasma View Post
    Hi Dean i have ordered new springs all round now, i have gone for a 30mm drop so should be about 15 mm lower than it would of been originally. at least it wont look like it is trying to pull a wheelie anymore!
    You still ok for tech 2 on the 19th? i have the auto light switch fitted already and just need to run the wires through to the REC for the light/rain sensor and should be away
  1. spring question
    By neill in forum Vectra C / Signum Car Chat
    Last Post: 9th January 2011, 17:28
  2. SRi Rear Spring Question
    By Fireyfella in forum Suspension, Wheels & Brakes
    Last Post: 30th November 2010, 22:35
  3. broken spring question
    By mgp in forum Suspension, Wheels & Brakes
    Last Post: 3rd January 2010, 12:53
  4. Spring seat mod question.
    By Big Sig in forum Vectra C / Signum Car Chat
    Last Post: 10th October 2009, 12:21
  5. Quick spring question
    By Dave1.8 in forum Vectra C / Signum Car Chat
    Last Post: 12th June 2008, 23:58
vectra c spring diffrence
