Results 1 to 10 of 14
Thread: Fault codes p0110 & p0105. EML on. Stuck in LHM
    Regular Member halster78's Avatar
    May 2011
    Lincoln
    Vehicle : Vectra C Estate
    Trim : Sri XP NAV
    Engine : 1.9CDTi (ps150)
    Default Fault codes p0110 & p0105. EML on. Stuck in LHM
    Hi
    My 56 plate 1.9cdti 150 is throwing up the above codes.
    I was driving along this afternoon and EML and spanner light came on. spanner light was intermittent. Pulled over and tried turning car off and key out and then back on and it clear for a mile or so them back on.
    Left it in car park at work. Came to drive home and EML light is on perm, spammer light no on at all. Engine stuck in limp mode.
    Checked code reader and getting 4 errors. 2 faults and 2 pending.
    P0110 & P0105
    Can anyone assist with these codes?
    Egr valve is relatively new but gave it a good clean tonight but no difference.
    Possible MAF & boost sensors?
    Any other suggestions? Would tech2 give any more detail?
    Cheer
    Al
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    P0110 is indicating you have a fault in the MAF and p0105 is a fault with your barometric pressure sensor .
    Now it is probably due to one or the other needing a clean they are next door to each other and connected . Another known fault with the vectra,s
    First course of action is to clean the Maf and sensor (have a look at the how 2 for this ) and give the sensor a clean as well
    If the Maf has gone faulty then it will affect the sensor but not the reverse
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 142000
    May 2011
    Lincoln
    Trim : Sri XP NAV
    Thanks for the replies. As always great info provided.
    Will give the sensors a good clean tomorrow.
    Where is the barometric sensor?
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    You can't clean the maf theirs mesh on each side of it
    Engine : 2.0DTi
    Mileage : 73350
    The barometric sensor is mounted behind the maf
    Regular Member Sebastian's Avatar
    Electric Heated Recaro Leather
    38 Post(s)
    Engine : 1.9 DTH
    Quote Originally Posted by dan danz View Post
    How about spraying electro contact cleaner on to it with straw ?
    May 2011
    Lincoln
    Trim : Sri XP NAV
    So here is my removed maf. Is there anything I can do with this?
    Still can't see the barometric sensor. Must be blind. How you mean directly behind?
    May 2011
    Lincoln
    Trim : Sri XP NAV
    Where is it?
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Quote Originally Posted by halster78 View Post
    I sprayed brake cleaner into that maf & then sprayed with elec contact spray, then i also removed the boost sensor & cleaned that also, problem solved for me.
  1. HELP PLEASE - Trouble codes: P1105-FA and P0105-FA
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 27th November 2015, 14:37
  2. PLEASE HELP!! Error codes p0100 & p0105
    By signum_05 in forum Vectra C / Signum Troubleshooting
    Last Post: 1st December 2012, 13:32
  3. Error codes p1105 and p0105
    By signum_05 in forum Engine & Drivetrain
    Last Post: 3rd July 2012, 12:58
  4. P0110 fault code on GSi - damn!
    By gtr1000 in forum Electrical & ICE (including SatNav)
    Last Post: 18th January 2010, 20:37
  5. 2 fault codes p0105 p1105 can any1 help??
    By barrymanalow87 in forum Engine & Drivetrain
    Last Post: 23rd September 2009, 09:08
00105 fault code opel vectra c
p0110 vectra c
p1105 zafira
zafira b p0105
opel astra g 1.7 dti p0110
astra H 1.9 cdti fault code P0105
opel astra g fault code 0110
Opel astra 05 fault codes 00105
vauxhall p110 code
p0100-08 vectra cdti 150
2.0 dti p0110
P0110 VAUXHALL VECTRA FAULT CODE
opel corsa c 2005 barometric diagnostic p1105
cod eroare astra h 00105
vauxhall zafira 1.6 2008 p0110 code
p0110 vauxhall
vectra c8de o0100
Vauxhall DTC P0110-1
astra h p0110 p0105
p0105 p0110 1.9 cdti
1.9cdti p0110
astra 1.9 cdti p0110
howbto fix code p110 astra 1.9
opel vectra c service code 00105
astra 1.7 p0110
