Thread: Coolant Leak
    Oct 2010
    Stevenage
    Default Coolant Leak
    Hi Guys, im hoping someone can help me.
    The past few day ive been losing a lot of coolant. After some investigation, i found the water coming out of a little hose which comes out of the bulk head. now it only leaks when the heating is , so im thinking is it the heater matrix?
    Dec 2011
    Seaham
    Shouldnt the pipe be connected back to something?
    Sounds like it could be the return from the heater matrix, but should go back to the engine.
    The only pipe that shouldnt be connected would be an overflow from the coolant bottle.
    Oct 2010
    Stevenage
    Hopefully the pic has come out. This is where the water is coming from.
    Oct 2010
    Stevenage
    South Central England
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    The two pipes going to the bulk head are to and from the heater matrix. Hopefully it's just a worn clam, try sticking a P-clip on it and see if that sorts it. Check for cracks and splits while you are there of course.
    Oct 2010
    Stevenage
    Cheers fella, i will try that. On the pic ive put a red box around an od shaped pipe, this is where the water seems to be coming from, but only when the heater is on. Is this some sort of over flow?
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    I can't look at the picture from work but I would guess the leaking pipe is the return pipe if only leaking when heater is on. The temperature control is just a value, so when off there should be no fluid flow to the return.
    That little pipe looks like the drain for the condensate from the aircon/climate control unit. If it is its normal to see water from there if the aircon is switched on.
  1. coolant leak
    By DavyB in forum Insignia car chat
    Last Post: 17th May 2012, 09:04
  2. Coolant leak
    By Vin in forum Engine & Drivetrain
    Last Post: 2nd February 2011, 22:49
  3. Coolant leak
    By mzctc7 in forum Vectra C / Signum Car Chat
    Last Post: 15th April 2010, 11:26
  4. Coolant Leak
    By trickydickySRI in forum Vectra C / Signum Troubleshooting
    Last Post: 20th April 2009, 09:25
  5. Coolant Leak???
    By ChrisFox in forum Vectra C / Signum Car Chat
    Last Post: 19th January 2009, 05:46
vectra c water leak at heater matrix pipe
