Thread: power steering problem
    Apr 2012
    Wigan
    Default power steering problem
    Hi all.
    i was parking up tonight (reverse parking) when the steering went dead, switched the engine off and back on and it went back to normal. Will it be the pump or lack of fluid?
    Nov 2010
    East Midlands
    Trim : design
    Quote Originally Posted by Mikewigan View Post
    Hi all.
    Could be pump or fluid but may also be a sign your alternator is on the way out!
    Apr 2012
    Wigan
    confused
    Quote Originally Posted by alcutler View Post
    Brilliant, only had the car 3 weeks, good job its under warranty. How would i know if its the pump/alt?
    Nov 2010
    East Midlands
    Trim : design
    If you do a search - you will find a lot of posts re the power steering / alternator problem - checking the fluid level is easy enough to do - if it was the pump you would have the problem all the time unless its in the early stages. i had it with the alternator could be driving all day long, stop ata junction start to pull away and get the warning light and no p/steering. The p/s draws a lot of power from the system and if the alternator/battery system is not 100%- the p/s is one of the first things to be affected.
    Take it back and get it sorted if its a warrenty job
  1. Power steering problem
    By Danwells72 in forum Vectra C / Signum Troubleshooting
    Last Post: 9th October 2012, 16:25
  2. On Going power steering problem
    By gazspeight in forum Electrical & ICE (including SatNav)
    Last Post: 29th November 2011, 18:18
  3. power steering problem
    By mr.d in forum Vectra C / Signum Car Chat
    Last Post: 9th August 2011, 22:33
  4. Power Steering Problem
    By llaregub in forum Electrical & ICE (including SatNav)
    Last Post: 3rd January 2008, 11:35
  5. Power Steering problem
    By H11LGX in forum Suspension, Wheels & Brakes
    Last Post: 22nd March 2006, 01:19
