Results 1 to 10 of 11
Thread: 'Over run' on engine
    Regular Member Porl's Avatar
    Apr 2012
    Barnsley, South Yorkshire
    Default 'Over run' on engine
    Hi
    Had my SRI 1.8 for a few weeks now and generally quite happy with it. Economy and performance are OK and comfy, good drive and lots of gadgets.
    I am still finding it hard to get smooth gear changes especially starting off and from 1st to 2nd.
    When I change up from 1st to 2nd the engine seems to carry on revving after I have released the 'loudest' pedal especially if I change up at around 2500 revs. If I change up with higher revs say 3500 or 4000 it seems ok.
    Is this normal? Am I a **** driver and just not used to the engine and gear box yet? Is there anything I should be doing? Any quick tests?
    I have been driving diesels for the past 3 years so I know I sometimes change up a bit early ( still does feel right going over 4000 revs!!) but there defo seems something a little up somewhere.
    Any advice gratefully received!
    Paul
    Regular Member rjw's Avatar
    Oct 2010
    cornwall
    Vx reduced the amount of oil recommended for the gearbox i believe on some models which rectified this problem which is well known of, not sure which engine/ gearboxes this was applicable to though.
    Sent from my HTC Sensation Z710e using Tapatalk 2
    Apr 2012
    Thanks that sounds like it could be the problem.
    The car was 'serviced' before i bought it and new oil put in. I'll try and get my regular garage to have a look and see what they say
    Full Member
    South West
    My 2.0T SRi does the exact same thing, i asked the exact same question and was told that its normal.
    Mines done it for the near on 5 years that i have owned it, dosn't seem to cause any problems.
    Regular Member Paulwr's Avatar
    Mar 2012
    Ormskirk, Lancs
    Vehicle : Astra H 1.8 VVT
    Trim : SRi XP 3dr
    Engine : Z18XER
    Mileage : 12k
    My 2.2 direct does the same too. The ECU seems to hold the revs high and not let them drop back down when changing from 1st to 2nd gear even with my foot off the gas. I've had the car about 7 weeks now and i'm still getting used to it.
    May 2011
    bispham, blackpool
    my 3.2 seems to do it only over 4k revs in first its never bothered me i thought it was normal so never even asked or looked in to it
    Regular Member gsi-robster's Avatar
    Mar 2012
    paisley
    my 3.2 does it
    think its to stop bucaroo effect in 1st and second if you keep it in that gear and come off the accelerator
    also the very short biting point on these ( mine anyway)
    still makes me a bit jumpy on the gear changes after i have been driving my van for a few days
    Dec 2011
    Seaham
    Supposedly a feature to make gear changing smoother for those people who cannot judge changes properly?
    Also heard it was to burn any additional fuel saving the cat?
    What ever it is, its blooming annoying!! I have driven for over 25 years, I can judge engine revs, gear changes and dont need a black box to do it for me.
    Any fixes? Tech 2 etc??
    Apr 2012
    Thanks for the feedback - at least I know it ain't just me!!
    It is ****** annoying though, is a remap of the ECU the only fix for it then?
    Full Member
    South West
    No difference to mine even after a remap
  1. 1.9 cdti Z19DT estate engine juddering plus white smoke coming from engine bay
    By danedragger in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2013, 17:44
  2. Can I replace a Z19DT engine with a Z19DTH engine, fairly easily?
    By Krusty3380 in forum Engine & Drivetrain
    Last Post: 13th August 2012, 15:24
  3. Engine lumpy now Engine Management Light is on
    By Fitzy-2.0T in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2012, 16:51
  4. Replies: 35
    Last Post: 5th May 2012, 15:32
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
