Results 1 to 10 of 15
Thread: Starter Motor Poblem???? Vectra 1.9 DTI 54 Plate
    Apr 2012
    Birmingham
    Default Starter Motor Poblem???? Vectra 1.9 DTI 54 Plate
    Hi Guys
    I've had my Vauxhall Vectra 1.9 DTi 54 Plate for over a year now but since the very first day its always had a starting problem not sure how to explain the problem but i will try.
    When i put the key in and turn it the starter motor makes a noise the starter motor noise but the engine takes a while to start i keep it turnt till it starts and it eventually does. Its normally fine on and off for the whole day unless you dont start it for a few hours or dont start it for a day or two the same problem happenes. Ive been living for this for over a year.
    Yesterday when i turnt the key the engine just wouldnt start and the starter motor ended up draining the battery which didnt help so i had someone tow me with a rope from the front while i jump started it, it jump started straight away no problem.
    I have had enough now so im going to try changing the starter motor to sort it out. My local breakers has a 2007 1.9 starter motor for £50 which im picking up in the morning and a mobile mechanic said he will fir it for £40 for me.
    I have a feeling that my starter motor is dodgy? What do you guys rekon this problem might be? is it a common fault?
    Thanks for looking. Any advise welcome.
    Regular Member hairytimes's Avatar
    Apr 2012
    norwich
    i think its more likely to be the duel-mass fly wheel?? like the tdcimondeo mk 4 i think???
    Apr 2012
    Birmingham
    I've done a seach for "Starter Motor" and "Wont Start" on this forum and from the few post ive read it seems like generaly its the starter motor causing this problem......?
    New Member DSS's Avatar
    Apr 2012
    Anglesey
    Clean the TDC Sensor.
    Apr 2012
    norwich
    is there a how2 on cleaning the tdc sensor??
    Apr 2012
    Birmingham
    where is the tdc sensor located?
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    It is not the starter motor, more likely sensor problem as has been already suggested. If not that you should be looking at fuel supply. Is your fuel filter clean? When was it last changed? Are your fuel lines leaking?
    3.2 v6 Signum and loving it
    Apr 2012
    Birmingham
    Spoke to 3 more people about this problem, 2 out of the 3 think its not the starter motor and one of them recomended Injector Cleaner Fluid so i put some in this morning we will see if this sorts it out. The other one said its need to go on the computer. Hopefully the fluid fixes it if not then it will need to go on the computer which aparently costs 30 odd quid.
    Wouldnt the computer just bring up all the problems the car has? How will you know which one it is? im sure the computer wont say your car isnt starting because of so and so etc etc?
    Regular Member Barlow's Avatar
    Jan 2012
    Chester
    Vehicle : Nissan 350Z GT
    Engine : 3.5 V6
    Year : 06
    Mileage : 50,000
    I'd read these two threads matey.
    I've got a very similar problem to you. Others have had the same problem. I think I've been persuaded that it's probably the starter motor.
    http://www.vectra-c.com/forum/showthread.php?t=159364
    http://www.vectra-c.com/forum/showthread.php?t=162870
    Apr 2012
    Birmingham
    Barlow, What seems to be the problem with your car?
  1. Starter motor
    By pjabrid in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2011, 22:40
  2. vectra 1.9d 150 starter motor fuse keeps blowing
    By badgerbaiter in forum Engine & Drivetrain
    Last Post: 8th December 2010, 20:41
  3. DMF vs Starter Motor
    By Maverick in forum Vectra C / Signum Car Chat
    Last Post: 30th January 2010, 19:34
  4. Help needed Vectra-C.. Starter motor or... ??
    By SRidale09 in forum General Chat
    Last Post: 22nd November 2009, 21:14
  5. new starter motor
    By magpie27 in forum Engine & Drivetrain
    Last Post: 19th May 2009, 13:46
vectra c 1.9dti keeps jumping
where is the starter on dti vectra
