Results 1 to 10 of 14
Thread: Snapped exhaust manifold/turbo stud snapped in cylinder head!
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    Default Snapped exhaust manifold/turbo stud snapped in cylinder head!
    1.9 150 z19dth engine. 81,000 miles.
    Has anybody had this problem before? I havent had time to strip down the whole front end of the car yet, looks like its snapped flush in the cylinder head.
    Anybody heard of this problem before?
    I snapped a stud on an old astra gte when fitting s SS manifold years back. New gasket and fitted the manifold, no leaks
    Dec 2010
    Glasgow
    Mileage : Near 100K
    i wasn't fitting a new manifold/turbo tho.
    Will need a new stud as its leaking and making a weird whisteling noise.
    May invest in a set of left hand 5% cobalt drill bits and a helicoil kit if the job turns into a complete disaster.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 141000
    http://www.vectra-c.com/forum/showth...haust+manifold
    go to post number 20
    hope this helps
    Dec 2010
    Glasgow
    Mileage : Near 100K
    Will check the mating face when it comes off, Thanks
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Quote Originally Posted by XPCobra View Post
    i wasn't fitting a new manifold/turbo though.
    Will need a new stud as its leaking and making a weird whistling noise.
    May invest in a set of left hand 5% cobalt drill bits and a heli-coil kit if the job turns into a complete disaster.
    Just use an ordinary drill bit, if the stud snapped because its seized, drilling left wont make any difference if you might be thinking it will turn out/undo whilst drilling it with a left hand drill bit, also they are only mild steel and don't take much drilling.
    An easy out might be an option for you.
    If it goes badly what ever way you do it, use "T-serts" or Time Serts, Wurth UK stock them, rather than heli-coils.
    Good luck.
    Dec 2010
    Glasgow
    Mileage : Near 100K
    Quote Originally Posted by C-Owner View Post
    If it goes badlty what ever way you do it, use "T-serts" or Time Serts, Wurth UK stock them, rather than heli-coils.
    Good luck.
    The stud snapped when i was driving it, the turbo has never been off the car (well at least for the last 30,000 miles i've owned it.) So i'm not sure if it is seized or not?
    Dec 2010
    Glasgow
    Mileage : Near 100K
    Used left hand drill bits and lots of penetrating oil to remove the snapped stud, fitted 8 new studs and new gaskets
    Just incase anybody else has this problem.
    May 2011
    South London
    Well done
    Not sure I've ever come across "snapped for no reason" exhaust studs before though on a standard engine !!
    Keep an eye on it
    Dec 2010
    Glasgow
    Mileage : Near 100K
    It does have a crd-t fitted so I suppose the extra heat may have caused the stud to fail.
    It seems to be common on r33 skyline engines, even when standard.
  1. 2.0t turbo/cat/exhaust manifold noise
    By rockhopper in forum Engine & Drivetrain
    Last Post: 9th March 2013, 00:23
  2. Snapped Wheel Stud
    By si_hoss in forum Suspension, Wheels & Brakes
    Last Post: 21st February 2011, 12:17
  3. Oh no i've snapped it
    By mr.c72 in forum Engine & Drivetrain
    Last Post: 16th June 2010, 18:14
  4. Exhaust Brackets Have Snapped
    By Darryl2.2DTI in forum Engine & Drivetrain
    Last Post: 23rd April 2009, 20:53
  5. snapped exhaust
    By Gr4eme in forum General Chat
    Last Post: 27th June 2007, 07:48
