Thread: Clutch pedal spring.
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Default Clutch pedal spring.
    Mine is making a very annoying creeeeeeek when I depress and release the pedal.
    these easy to change - ive sprayed it up but no difference.
    Blantyre
    Very easy mate , 5 min job,
    Middlesex
    Trim : SRI
    Mileage : 100k
    Quote Originally Posted by spennny View Post
    Yeah - so this is the one isnt it:
    http://www.vectra-c.com/forum/showth...h+pedal+spring
    Mine looks like the one in pic one in this thread - i.e. a gap in the spring:
    Will get one and see how I go
    Middlesex
    Trim : SRI
    Mileage : 100k
    Is the part the complete 'white thing' that you see or litrally just the spring?
    Regular Member gsi-robster's Avatar
    Mar 2012
    paisley
    2 white halves with 2 springs im sure between them.
    one spring you can see and a smaller diameter one inside it
    id check the actual pivot of the pedal for creaking
    use a grease to lube ( chain lube )and not a penetrating oil ( wd40)
    just my eperience for the coating to last longer
    also check the plastic linkage to the clutch master for a coating of grease and the security of the actual master cylinder to bulkhead
  1. clutch pedal spring
    By monkyspunky in forum Bodywork & Interior
    Last Post: 1st May 2011, 13:50
  2. clutch pedal spring
    By Big Knox in forum Vectra C / Signum Car Chat
    Last Post: 15th April 2011, 13:38
  3. clutch pedal spring
    By carl bear in forum Vectra C / Signum Car Chat
    Last Post: 12th October 2010, 11:58
  4. clutch pedal spring
    By paul429 in forum Engine & Drivetrain
    Last Post: 20th March 2008, 15:53
