Results 1 to 10 of 11
Thread: HID
    Full Member dezzyb66's Avatar
    Aug 2011
    carlisle
    Vehicle : Vectra c
    Engine : 1.9cdti 120
    Default HID
    ive just fitted some hids and they flicker and then go out is there a fix for this problem
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    As long as the units are new i.e. not broken, then you can either add the error fixing capacitors or get the xenon option turned on via tech2 or equivalent
    Aug 2011
    carlisle
    Vehicle : Vectra c
    Default HID
    who has tech2 is it mostly vx dealers
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Many members on here have an 'equivalent' so someone might be able to help you out. You'll find the dealers are next to useless with tech2 though.
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Regarding the flickering, Cancellers alone won't stop the flickering, It'll likely be due to the Ballasts being incompatible. You need Canbus compatible ballasts to stop the flickering, and the error cancellers for the bulb-out warining light.
    Activation of xenons can also be done through Vauxcom, there's a few users on here that may be able to help you out.
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Quote Originally Posted by MrDerv View Post
    Mine were just standard error cancellers and only one flickered prior to installing them. Fitted them about 2 days before i had xenons activated whilst having a tech2 session. Money wasted
    Aug 2011
    carlisle
    Vehicle : Vectra c
    Default HID
    what was a waste of time the tech 2 or the cancellers
    Nov 2011
    Cancellers i suspect, once you have the HID's activated in a tech2/vauxcom session, then you don't need them, so long as you have canbus compatible ballasts
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Quote Originally Posted by dezzyb66 View Post
    Cancellors.
    Aug 2011
    carlisle
    Vehicle : Vectra c
    so how much is tech 2 then
