Thread: Cim Replace
    Mar 2011
    Danmark
    Default Cim Replace
    Vectra c Replace CIM 13204166 UY with 13204147 UZ is this possible.
    I have tried it and get two Faulty codes U2139-71 Can-bus CIM Message Rang Perfomance..
    C0460-42 Steering Angel Sensor groove Calibated (have tried many times to delete but get errors each time)..
    Has today been with Opel they tried for over two hours and finally they said that Cim 13204147 UZ is only for service vehicles (police ambulance, etc. Can it be true.
    Is there anyone who has tried to replace the CIM 13204146 UY with 132041147 UZ
    There is a vectra c facelift 2006 with z18xer engine
    Full Member
    Bristol
    Quote Originally Posted by Markov View Post
    Cim UY can be replaced with UZ accordining to Vauxhall part no
    Full Member Robsey's Avatar
    North East Cheshire
    21 Post(s)
    Trim : Energy
    Mileage : 131,000
    A total long-shot on this one...
    Is there anything else on the car that does not work?
    I ask this, as I have known Tech 2 to not work, simply because a brake light bulb was out. - Strange but true.
    I understand the programming sequence for a CIM is VERY complicated.
    I wonder if your dealer knows the correct sequence for this.
    It involves a lot of resetting and re-pairing up a couple of the modules, and setting up of the keys...
    Final job should be the calibration of the steering angle sensor.
    As far as I am aware, UZ is a direct replacement for UY.. just a slightly newer module.
    Admin plasma's Avatar
    On the Forum
    323 Post(s)
    Engine : 150
    Mileage : 74000
    UZ is a higher spec module which is used with AFL's, but is a replacement for UY
    And resetting a CIM on tech2 is fairly striaght forward, but not so much so if using vauxcom.
    for claritys sake tech2 pushes around the codes to all the other modules on the immobilser circuit, DDM, PDM, REC, etc etc and gets it to learn the new CIM... Whereas with Vauxcom you have to manually reset each module and get it to learn the new environment identifiers which is a tedious job.
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    On the Forum
    323 Post(s)
    Engine : 150
    Mileage : 74000
    got this around the wrong way, think the UY is a newer replacement for the UZ
    (IDENT UY ALSO SERVICES IDENT UZ) (WITH ACCESSORY POWER OUTLET SOCKET) (2 CONNECTORS) (FOR 433 MHZ FREQUENCY) (EXCEPT AUTHORITY, POLICE VEHICLES)
    btw, think your part number for UY is miss typed, think you mean 1324146 and not 13204166
    think the UZ has a built in steering angle sensor which is needed for the AFL's to work, so maybe something to do with that relates to the error your getting
    North East Cheshire
    21 Post(s)
    Trim : Energy
    Mileage : 131,000
    Thanks for the clarification -
    EPC4 can be a bit clunky with it's wording.
    Hmm Vauxcom - It has some bonus sides (especially the infotainment side), but for all other programming etc, you simply can't beat Tech 2 / Tech 3, TIS2Web.
    On the Forum
    323 Post(s)
    Engine : 150
    Mileage : 74000
    pm me Robsey about benefit of vauxcom on infotainment side pls..?
  1. Can i rip out and replace?
    By bbdp in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2012, 11:17
  2. Replace 215/55/16 with 195/50/16
    By battsman in forum Suspension, Wheels & Brakes
    Last Post: 14th February 2012, 16:18
  3. Replace my TID with a dvd?
    By ryantcb in forum Electrical & ICE (including SatNav)
    Last Post: 30th June 2011, 15:46
  4. Tie rod replace
    By blackveccyC in forum Suspension, Wheels & Brakes
    Last Post: 28th November 2010, 15:15
  5. Need to replace all 4 springs - HELP!
    By Screechxl in forum Suspension, Wheels & Brakes
    Last Post: 6th February 2009, 18:46
https:www.vectra-c.comforumshowthread.php162982-Cim-Replace
cim replacement with tech2
calibrirane steering angel sensor on vectra c
fallo u2139-71
13204147 or 13204146
cim 13204147 calibrate
u2139-71 vectra c
