Results 1 to 10 of 20
Thread: anybody had their fuel pump go? metal filings in the fuel filter?
    Mar 2007
    Sheffield
    Default anybody had their fuel pump go? metal filings in the fuel filter?
    I have just had a complete mad as a bag of cats phone call with the stealership......
    metal filings in the fuel filter suggest a fuel pump failure apparently.
    I also have a problem on the no2 injector.
    So the stealership want to replace 6 injectors and a fuel pump and clean out the system at a cost of £6,700.............
    Anybody else has their fuel pump go, and what was the resolve? how much did it cost? did the problem turn out to be something else, or was their linked problems?
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 135000
    is this the 2.2 engine
    Mar 2007
    Sheffield
    Quote Originally Posted by vectra ste View Post
    nope, 3.0 V6 Izuzu engine versions.
    It possible that other models use the same fuel pump? or are elidgable for the same issues?
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    not with six injectors and in the 'Y & Z30DT Specific' section its not
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 135000
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 135000
    South Central England
    10 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Half that cost will be labour, you can get a second hand pump from ebay for hundreds I'm sure and get it reconned by a Bosch diesel pump specialist. The injectors can be reconned at the same time and you don't need the stealers to change the pump and injectors.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 135000
    any good zerocool?
    Mar 2007
    Sheffield
    Sorry ste.
    I'm no expert but I imagine that as most of the engine parts are Isuzu diesel I imagine they will be completely different to the petrol 2.2.
    It seems to be common failure on the 3.0 so it probably deserves its own watchdog style complaint.
    I am here: http://tapatalk.com/map.php?kwy5aj
    Mar 2007
    Sheffield
    I have more to learn about the fuel pumps on this vehicle.
    am I right in saying there is not a pump in the tank?
    The swarf is pretty bad in the fuel from the amount of time the new fuel filter has been in.
    Diesel specialist is working on the car now, no2 injector is wrecked so I will need to replace it.
  1. 2.2 direct fuel pump and fuel pressure regulator
    By w111y in forum Engine & Drivetrain
    Last Post: 11th July 2012, 22:12
  2. Whine from the back seat - Fuel Filter or Pump
    By coldo in forum Vectra C / Signum Car Chat
    Last Post: 17th May 2012, 20:24
  3. high pressur fuel pump and fuel regulator ?
    By simplesi in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2010, 12:23
  4. How do i remove the fuel lines from 3.2 fuel filter...?
    By killer_bunny in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2010, 23:07
  5. Fuel pressure sensor/fuel pump failure list following Watchdog investigation.
    By happychappy in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2009, 13:18
