Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
Thread: wet front passenger footwell
    Regular Member J P S's Avatar
    Sep 2011
    Birmingham
    Vehicle : 2007 1.9cdti sri 150 estate
    Trim : sri
    Engine : 1.9cdti 150
    Default wet front passenger footwell
    i did a search but that only revealed two threads about rear footwells and this is the front one.
    just discovered this am typically, couldnt have found it before the weekend of course!
    any idea what the most likely cause is please?
    Regular Member sheepish's Avatar
    Yorkshire
    Regular Member Gubmint Agent's Avatar
    Feb 2011
    Feels a lot like Kathmandu.
    Trim : Sri
    Engine : 2.2 Direct
    Blocked scuttle drain.
    edit: beaten to it.
    Sep 2011
    Birmingham
    Trim : sri
    thank you, i didnt search properly obviously.
    will get it checked then thank you
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 127000
    http://www.vectra-c.com/forum/showth...t=scuttle+tray
    see to here that mate i started this thread to warn people
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 127000
    here you go mate
    ive been there
    http://www.vectra-c.com/forum/showthread.php?t=108462
    all you need is a new pollen filter 10 pounds at dealer
    around 5 pounds ebay
    Sep 2011
    Birmingham
    Trim : sri
    in all honesty i think i did buy a pollen filter and if i can find it will swap it over, failing that will order another just to be safe
    Wirral, UK
    Vehicle : Meriva B
    Trim : SE
    Engine : 1.7CDTi
    Year : 2011
    I took the rubber part of the passenger side scuttle drain out to reduce the chances of it getting blocked.
    There is also one on the drivers side, but it is far more difficult to get too.
    It can be cleared with a stick tho'.
    Sep 2011
    Birmingham
    Trim : sri
    something to bear in mind.
    the bigger issue is i have no idea when i will get chance to do this this week, hopefully the rain will let up a bit!
    Regular Member adierolfe's Avatar
    Feb 2012
    Corris
    It's literally a 2 minute job.
  1. Vectra C 1.9 2006 Facelift - Front Passenger footwell full of water
    By ciscokid75 in forum Vectra C / Signum Car Chat
    Last Post: 31st January 2013, 11:48
  2. Sopping Wet Passenger Footwell Front & Rear
    By Sweeneyz in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2012, 12:12
  3. Wet passenger footwell
    By aaruck in forum Engine & Drivetrain
    Last Post: 2nd October 2010, 11:13
  4. wet passenger footwell
    By n8sby in forum Vectra C / Signum Car Chat
    Last Post: 29th April 2010, 20:40
  5. wet passenger footwell
    By al21784 in forum Vectra C / Signum Car Chat
    Last Post: 2nd December 2007, 23:42
vauxhall vectra wet passenger footwell
