Results 1 to 10 of 14
Thread: V6 CDTI SMOKING...... but just once!?
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Trim : Irmscher Elite
    Engine : 3.0 CDTI
    Default V6 CDTI SMOKING...... but just once!?
    I was sat waiting for the Mrs to come out of the doctors for maybe 1/2 an hour with the engine running, listening to the radio. She came out and we started making our way home. After about 200 yds, plooms of blue smoke started coming out of the exhausts under load. I pulled over to take a look, there was still the remnants of the blue smoke coming from the pipes. I lifted the bonnet, gave it a rev to see if i could hear or see anything unusual. Nothing. Not even the blue smoke. I phoned the 'guru', he told me a few things to look for, all seems ok.
    After i set off again, i (gingerly) give it the beans. No smoke, no nothing, everything seems to be ok.
    I have plenty of oil left in, no gunk around oil cap, 3/4 tank of shell diesel, on oil spoit around intercooler or turbo hoses.
    Am i heading for disaster? Has anyone had this happen to them before?
    Probably just because it was sat idling for half an hour mate - I'm sure it'll be fine...
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Mine smokes white/blue if it's left idling for too long. First time I noticed it was in really slow traffic (move 2 feet, idle for 10min, 5 feet idle 10min,...)...I booted it after 2 hours of basically just idling...plumes of white/blue-ish smoke. It cleared after a few seconds.
    Regular Member ben_3.0v6's Avatar
    Apr 2011
    EMEC #3
    Could this be a sign of a worn DPF? (Only a suggestion)
    Do either of your cars have them?
    Sep 2010
    Right here, right now.
    6 Post(s)
    Trim : SRI
    Engine : 3.0 V6 CDTI
    Y30DT engined cars don't have DPFs mate, just us Z30DT boys. They have lower power outputs though.
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    i don't have one. Been on a 'demanding' run, gave it some pain, all seems ok. I'll tell you, it put the wind up me though
    Regular Member Dane-10's Avatar
    Feb 2012
    Sheffield
    I've had this with other cars, Sitting on idle for longer periods then giving it some beans and get the odd plume of smoke.
    I wouldn't worry unless it happens on a regular basis.
    Mine does that as well, quite normal
    The Y30DT does not like long periods on idle or low revs
    Apply lots of power suddenly, and you get loads of smoke (unburnt fuel)
    I have personally put this down to the EMS program
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Cheers guys, I've just been on a run to York and back, no issues, so i guess it's like you say. Although i just discovered that last time i washed the car i removed the rear lights to clean out the algae and didn't replace the seal correctly...... spare wheel housing, full of water
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    It's all sorted I belive Wilko rang me I advised him all is ok now
  1. Cdti smoking badly
    By gtirobbie in forum Engine & Drivetrain
    Last Post: 17th July 2012, 13:44
  2. Smoking cdti 120??
    By frasedeb in forum Engine & Drivetrain
    Last Post: 6th July 2012, 15:02
  3. Smoking CDTi 150
    By rockafella8587 in forum Engine & Drivetrain
    Last Post: 2nd December 2011, 11:57
  4. Smoking Signum 3.0 v6 CDTI
    By natvx220 in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd August 2010, 17:56
  5. Smoking CDTI
    By km101 in forum Engine & Drivetrain
    Last Post: 10th January 2007, 22:07
