Results 1 to 10 of 20
Thread: egr delete kit
    Regular Member ftm100's Avatar
    South Shields seagull sh*t town
    Default egr delete kit
    Just spotted this on ebay http://www.ebay.co.uk/itm/Allard-Alf...#ht_1911wt_954
    and as the alfa engine is the same was wondering if any one has tried or has any opinons on it?
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    We have the 8v version in our 02 Punto but its way off the mark compared to the CDTi in the Vec, the physical engine may be the same but the electrics are of an older genaration, this may also be the case in the old 156's, I looked at one of them before I got the Vec and that was 7 years ago.
    Just been on their web site and this is what they say about it:-
    Q. If I fit your egr delete will an ecu warning light show.
    A. Generally if you have a mechanical ( vacuum controlled ) egr valve an ecu dash warning light will not show. With regard to later 1.9 and all 2.0 models with electronic egr valves yes it will register an ecu dash light. Don't worry though as almost all engine mappers can now delete the egr function from an ecu.
    So it looks like it could be a replacement.
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Its just the same as blanking it then and many have done it, as far as im aware you only need a blanking plate, not the power pipe thing.
    Looking at the pictures of it fitted looks like it replaces the throttle body as well
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    I think its the actual whole EGR not TB
    comparing pictures 3 and 4 they have removed the tb and put that pipe in it place
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    There's plenty of threads on google mate, the Alfa forum said it put there car into limp and it needed software to run fully.
    suppose im just living in hope lol
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Although it seams other Oil burners (VW Audi Ford) work well with Allard products.
  1. dpf removal and egr delete
    By J P S in forum Vectra C / Signum Car Chat
    Last Post: 8th June 2012, 10:37
  2. Delete
    By ads3 in forum Introduce yourself.
    Last Post: 14th September 2005, 19:14
vectra c egr delete kit
vectra egr delete www.vectra-c.com
