Thread: Any ideas of what would cause this ABS Fault code?
    May 2006
    scotland
    confused Any ideas of what would cause this ABS Fault code?
    C0035 - Front Left Wheel Speed Sensor Circuit High Voltage
    (01) - Not present
    It is the high voltage that is confusing me. If there was a bad connection in that circuit, I thought it would cause a low voltage. I have no clue what (01) - not present means.
    Upon visual inspection, the wiring looks ok in that area. Connectors are of newer type.
    When the car is cold (eg. first thing in morning), the ABS/TC warning lights are out and the wheel sensor live data is showing front n/s wheel sensor is working ok (i.e speed is in unison with all other wheels), but after normal driving and braking over a period of about 15 minutes, the ABS\TC lights always illuminates at the moment the car comes to rest (never pulses the brake pedal) and when driving away again, the wheel sensor live data is then showing wheel speed of front n/s wheel as 1 whilst the other wheels are showing the correct speed the car is travelling at.
    It is almost as if thermal expansion of a component is having an effect and causing the malfunction. Strange one.
    Any input would be appreciated.
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    Sounds like sensor breaking down when hot
    May 2006
    scotland
    Quote Originally Posted by troutybrown View Post
    Thanks for that.
    The '(01) Not Present' I worked out that it has been a fault but at the time of reading the fault code, the fault was no longer present. I managed to catch it today when the fault was present.
    It does seem as if the sensor is breaking down at temperature. Its now very repeatable. I can almost predict the exact set of traffic lights the ABS warning will illuminate.
    May 2006
    scotland
    Update on this fault. Took it to an auto electrician and he disconnected the sensor at the connector on the front suspension strut and measured the resistence of the sensor one way then swapped the DMM probes and tested in the other direction. He decreed the sensor gave the correct readings. he then connected the connector back up and disconnected the wiring at the connector just prior to it dissapearing into the inner wing. The resistance of the sensor readings was much reduced than that of the first readings. His diagnosis was a part short within the wiring harness. He has ordered a new harness and describes it as the harness between the first connector to the second connector (before it finally goes up to the ABS ECU in the engine compartment). Fingers crossed that it is as simple as this.
    May 2006
    scotland
    Update for anyone interested. Fault fixed. It was the wiring harness that went from the first connector to the second connector under the front NS wheelarch. Replaced the old one with a new genuine VX cable.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Glad you fixed it mate
    Shows sometimes it's worth an hours labour to an experienced person
    May 2006
    scotland
    Yes, agreed. Sometimes you just cannot beat good old been there, done it, have the tee shirt
  1. vectra cdti sxi 120ps ecu code u2103...any ideas what it is?
    By big rich in forum Engine & Drivetrain
    Last Post: 27th December 2011, 21:01
  2. code p1405 any ideas?
    By victorM in forum Engine & Drivetrain
    Last Post: 5th October 2011, 22:24
  3. Car Died again - Fault Codes PResent - Any ideas :(
    By vectraboyy in forum Engine & Drivetrain
    Last Post: 25th July 2010, 19:05
  4. Wing Mirror - Fault! any ideas?
    By dv8 in forum Electrical & ICE (including SatNav)
    Last Post: 1st October 2009, 01:25
  5. 2.2 DTi SRi fault codes any ideas?
    By joyrider in forum Engine & Drivetrain
    Last Post: 7th March 2009, 23:23
OPEL C0035
VAUXHALL C0035
vectra c error code C0035
Vauxhall DTC C0035-06
c0035 abs code vauxhall
c0035-06 opel
Opel DTC C0035-06
Opel DTC C0035-00
abs fault on insignia linked to wheel sensor
Opel DTC C0035-8
c0035 abs code vauxhall insignia
Vauxhall DTC C10C3-0E
vectra c c0035
c0035 opel
remediere eroare c0035 la opel
c0035 insigniacoo35-03 vauxhallVAUXHALL VIVARO CODE C10C3Opel C0040-0FOpel DTC C10C3-0Eopel zafira klaida C0035vauxhall dtc c0040-26 u2103-00c0035 abs codec0800 vauxhall abscorsa c0035
