Thread: fuel pump in tank noisy
    Regular Member dbgb25's Avatar
    Aug 2009
    Margate kent
    Default fuel pump in tank noisy
    Then turn ignition on can hear whining sound from the tank is it normal cos 4 months ago have problem with the low presure on fuel system . So replaced fuel presure valve on the back of HP pump and car was running fine. Is still runs ok but pump in tank is noisy. And then ignition on my fuel lines witch goes in to the fuel filter looks like going explode or is it normalthem to move alot ???
    Aug 2009
    Margate kent
    any one ...
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    dunno mate, but i have a spare pump that should be fine in yours if you need it, I took it out of my 2.0T, it did not make any noise..
    Aug 2009
    Margate kent
    are they the same???
    Jun 2009
    South Coast
    I reckon so, my engine is derived from yours, just essentially a shorter stroke and a turbo... I am currently assuming you have a 2.2 as you referred to the HPFP
    Aug 2009
    Margate kent
    no my one is 1.9 16valve
    Jun 2009
    South Coast
    ah well, ignore me for now then, if you can get the part number/type for your pump i still may be able to help.
    Aug 2009
    Margate kent
    you think the pump in tank is faulty? or is HP pump is faulty or again that fuel presure regulator on the pump?
  1. EHPS Pump very noisy
    By alanlush in forum Suspension, Wheels & Brakes
    Last Post: 23rd October 2012, 14:47
  2. NEED in tank fuel pump ASAP!!!!
    By bangty 1 in forum Vectra C / Signum Car Chat
    Last Post: 27th November 2010, 16:04
  3. Fuel pressure sensor/fuel pump failure list following Watchdog investigation.
    By happychappy in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2009, 13:18
  4. Noisy pulley/water pump
    By rosssri in forum Engine & Drivetrain
    Last Post: 18th December 2007, 11:03
  5. 2.2 DTi in-tank fuel pump.
    By Ross DTi 2.2 in forum Vectra C / Signum Car Chat
    Last Post: 20th September 2006, 22:38
vaughall vectra fuel pump noise
