Thread: Windows tints, but without using tinting foil
    Regular Member Barbara's Avatar
    Jan 2006
    Berks
    Default Windows tints, but without using tinting foil
    Hi guys
    I was wondering if anyone of you know where I can do anything like this ;] how it is working:
    First you have to remove your car windows (or they will do it) then they are put into a special furnace (oven) where they are subjected to a special process based on ultra low pressure fusion of glass and gases of rare metals (like Titanium, Indium)
    Advantages:
    Photohrome effect - window becomes darker during daytime and lighter when sun light gets dimmer.
    Solar effect - decrease in car's insight heat absorbency by up to 65%.
    Protection against harmful UVA & UVB rays.
    Several times longer life span in comparison to window with film applied.
    Increased durability for scratches and nick damages, but the best thing about this is,
    decreasing visibility from outside of a car but there is absolutely NO visibility loose from inside of a car! look
    or where except from (http://www.karmannkonnection.com/ 800£ per set) can I chrome alloy wheels ?
    Regular Member Orka The Porka's Avatar
    Oct 2006
    North Rochford (The Posh End)
    If you can come down to the essex area there is a tint guy called terry. (If you want his number PM me.) He charges £25.00 a window. He does everything.
    Jan 2006
    Berks
    Quote Originally Posted by Orka The Porka View Post
    He does everything
    Alright, but is he doing tints using this technique?
    spoons
    Guest
    OK, I dont know anything about this at all... but, here are some logical questions.
    If they are processing the existing glass, how scratch resistant is the processed coating..... If its like Oakleys (sunglasses) then I would imagine that its not very scratch resistant at all. This could be a problem.
    Also, how long does this process take once the windows have been removed. This could be an inconvenience, if your side window is smashed and you need a replacement.
    How does the tint (at its maximum photochrome tint) effect the police check system for the laws on window tinting ?
    How fast reacting is the photochromatic process. i.e. from light to dark environments (car parks, tunnels etc) will you be in a situation where you cannot see through the side windows, as an example.
    Covering the glass with a coat of Titanium etc, would this effect the signal for portable satellite navigation systems?
    EDIT: Looks good though
    Regular Member nickc's Avatar
    Jul 2006
    newport, shrops
    some good points there spoons.
    also at the bottom of the original post - am i correct in saying it costs £800 to have them tinted using this process??
    member of the smoke patrol 230bhp+
    this is used on glass doors in banks a lots
    i bet its not cheap to do a car
    i asked about this when id seen it on glass doors and got told the push and pull on the glass door was around "£200"but was a few years ago
    what i seen was a littel diffrent ,,,,what was on one side couldnt be seen from the other side
    id love to know a price to tint a car
    iv seen a site thats in poland that dose this
    http://www.technicolor.pl/english/szyby.html
    Jan 2006
    Berks
    Quote Originally Posted by spoons View Post
    O
    1.If they are processing the existing glass, how scratch resistant is the processed coating..... If its like Oakleys (sunglasses) then I would imagine that its not very scratch resistant at all. This could be a problem.
    2.Also, how long does this process take once the windows have been removed. This could be an inconvenience, if your side window is smashed and you need a replacement.
    3.How does the tint (at its maximum photochrome tint) effect the police check system for the laws on window tinting ?
    4.How fast reacting is the photochromatic process. i.e. from light to dark environments (car parks, tunnels etc) will you be in a situation where you cannot see through the side windows, as an example.
    5.Covering the glass with a coat of Titanium etc, would this effect the signal for portable satellite navigation systems?
    1. It's very hard to scratch it, trust me ;]
    2. 4-6 hrs with removed windows, 8-12 with removing.
    3. Haven't got a clue ;] I know police should be able to see the driver inside the car, but if in maximum photochrome tint from outside, you have no visibility loose from inside it's better than tinting film anyway.
    4. I dont know aswell, but who cares about how fast it is reacting, as long as you are inside, your windows ar not affected.
    5. Front windscreen is not covered, I think it is against law in all EU countries, but you can have a problems with your side windows ;]
    Price I think 300 to 400 depends on the car should be fair enough.
    Quote Originally Posted by nickc View Post
    no I was asking about alloy wheels chroming, the only place to get them done is probably http://www.karmannkonnection.com/ and they are doing it for 800£ per set, I should be able to do it for 80-120 per wheel depends on wheel size, thats why I was asking ;]
    Jul 2006
    newport, shrops
    sorry my mistake,
    300-400 doesnt sound too bad then, i think national firms like tintmaster charge £250ish for the whole car.
  1. Tried my hand at tinting my windows
    By v6signum in forum Styling
    Last Post: 19th November 2012, 00:46
  2. Looking into tinting the windows
    By Ralphwells1967 in forum Vectra C / Signum Car Chat
    Last Post: 4th April 2012, 01:07
  3. what's in the foil?
    By darko2301 in forum The 'Off Topic' room
    Last Post: 18th April 2009, 12:56
  4. Windows Wipers and Windows Washers
    By kevrod79 in forum Electrical & ICE (including SatNav)
    Last Post: 19th February 2009, 09:58
  5. Replies: 0
    Last Post: 25th June 2005, 16:13
