Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: 1.9 Fuel filter housing?
    Regular Member Barlow's Avatar
    Jan 2012
    Chester
    Vehicle : Nissan 350Z GT
    Engine : 3.5 V6
    Year : 06
    Mileage : 50,000
    Default 1.9 Fuel filter housing?
    Probably a long shot this.
    Does anyone know which fuel line on the filter housing sends the fuel in? the top or bottom one?
    I guess one is 'In' and the other is 'Return'?
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    They normally have an arrow on them indicating the flow direction
    Irmscher Insignia CDTI 130
    Jan 2012
    Chester
    Engine : 3.5 V6
    Year : 06
    Mileage : 50,000
    No, there's none there that I can see.
    Nov 2010
    East Midlands
    Trim : design
    Would it be possible/safe to disconnect one and switch the ignition on - you'd need a container to catch the fuel as it comes out?
    Jan 2012
    Chester
    Engine : 3.5 V6
    Year : 06
    Mileage : 50,000
    That's my last resort. Messy way of doing it
    Nov 2010
    East Midlands
    Trim : design
    Be careful - Make sure its safe to do it - wont the fuel come out with some force once the pump tries to pressurise the system?
    Jan 2012
    Chester
    Engine : 3.5 V6
    Year : 06
    Mileage : 50,000
    Quote Originally Posted by alcutler View Post
    No idea at all to be honest. At least it's diesel not petrol. Not easy to ignite diesel.
    Bristol
    Vehicle : CDTI 150
    The 1.9 uses a lift pump in the tank, you will get a lot of diesel come out so not the best thing to do.
    Sorry cant remember which pipe does what.
    Why do you need to know?
    Jan 2012
    Chester
    Engine : 3.5 V6
    Year : 06
    Mileage : 50,000
    It's really hard to start after sitting for a good while. I've replaced everything that it could be.
    My theory is that the diesel is running back to the tank, so I want to fit a non return valve on the correct pipe.
    Apparently this problem is not uncommon on diesels of any make.
    Bristol
    Vehicle : CDTI 150
    As the CDTI has a lift pump try switching on the ign for 10 secs then off then try starting that should fill the pipes with diesel and confirm if diesel is leaking away.
    When it does start do you get a cloud of white smoke from the exhaust? if so could be a leaky injector, you can confirm with a leak off kit.
  1. fuel filter housing
    By daddyjay in forum Parts for sale
    Last Post: 8th October 2010, 19:14
  2. fuel filter housing
    By daddyjay in forum Vectra C / Signum Car Chat
    Last Post: 26th September 2010, 13:19
  3. fuel filter housing
    By babsandy in forum Vectra C / Signum Car Chat
    Last Post: 28th March 2010, 14:11
vauxhall injector deviation
