Thread: The curse of the 1.9 cdti Sri 150 strikes again
    Apr 2012
    Cambridge
    Default The curse of the 1.9 cdti Sri 150 strikes again
    Having a problem with my vectra 05 cdti Sri 150
    A few weeks ago I pulled away from junction and had power for a second and now have no power.
    I have changed the O2 sensor as had it plugged in and that was the only problem computer found at time. This didn't do anything
    Also had an injector replaced as this was returning a lot less fuel than the other 3 injectors this made a very small improvement
    Now computer is saying something about swerl flaps but seems like this can't be all that's the problem to me
    ATM the car revs to about 3000 rpm won't go any higher and 40 is max speed with thick white smoke out back. I have also been told that fuel pump is the normal problem but as its thick white smoke I would say poss over fuelling ??
    Any help would be great
    Engine : 1.9 CDTi
    Have you checked the condition of the swirl flap (As thats the code) or cleaned the egr?
    Apr 2012
    Cambridge
    Egr been cleaned but not had manifold off yet to check swirl flaps. Just can't afford to spend money doing that if it won't fix problems as this error code didnt come up to begin with
    Engine : 1.9 CDTi
    Just take the engine cover off and see if the bar is still attached and if there is oil around the pivot points.
    Also get someone to rev the car and see if number 3 flap moves when rev'ed.
    Apr 2012
    Cambridge
    Bar was off but was placed back on. The bar moves to begin with till the error code comes up then it stops moving, just really wanted to know if this can cause the problems I'm getting
    gwent
    Yes it will cause the problem as the swirl flap is sticking as with my own car did a actuator test and the flaps won't close shut and won't open all the way. The last couple of day had a fault code and gone into limp mode cleared fault but has come back car is under power at the moment but drives ok have ordered a new inlet manifold and all the parts to do the job.
    Apr 2012
    Cambridge
    Would this cause the thick white smoke too?
    gwent
    I don't know as my back window is black out but like I said it will cause a lack of power
  1. The Vectra C.COM Curse/
    By markone in forum Vectra C / Signum Car Chat
    Last Post: 26th December 2011, 15:22
  2. The vectra curse strikes again!
    By byebyeitsagsi in forum Vectra C / Signum Car Chat
    Last Post: 5th May 2009, 18:27
  3. Snowflake curse strikes me again !!!
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 26th March 2008, 17:07
  4. The curse continues
    By DennisTheMenace in forum Vectra C / Signum Car Chat
    Last Post: 6th March 2007, 23:31
  5. The curse of ultra blue
    Last Post: 22nd February 2007, 18:18
