Thread: 1.8 petrol vectra c
    Mar 2012
    newcastle upon tyne
    Default 1.8 petrol vectra c
    hi guys ive got a 2003 vectra c 1.8 petrol
    im looking for a coil pack.
    can anyone recommend to me where i can get on from but not to be ripped off by vauxhall?
    its a bad started when cold and worse when hot ive changed the plugs, crankshaft sensor, the cold start sensor and had the timing done also a servise and theres no change. spoke to a mechanic from the taxi company i used to work with and he recommends changing the coil pack.
    it does Eventually start when cole after about 1-2 mins but when hot it takes roughly 5 mins to start
    anyother info someone can pass me id be eternally grateful because its my 1st vectra and i do like it better than the mondeo but if i cant get it fixed ill be going back to ford
    thanks guys
    andrew
    hull
    may be a faulty ecu mate, had this on my vec b.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 141000
    http://www.ebay.co.uk/itm/Vauxhall-V...item43af52ee53
    here you go
    i got one off ebay for a member on here for 25 pounds and it worked a treat
    its a common fault that the coilpack goes on the 1.8
    its better than paying 90 pounds at the dealer
    take you pick
    http://www.ebay.co.uk/sch/i.html?_fr...All-Categories
    vectra ste
    Dec 2011
    Seaham
    Can you borrow a good one to try on your car before you buy?
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 141000
    Quote Originally Posted by Ben50n View Post
    good idea and a bit of lube
    Dec 2011
    Seaham
    Quote Originally Posted by vectra ste View Post
    Think you have chain lube on the brain now!
    But you know it works!
    Mar 2012
    newcastle upon tyne
    thanks for the replies
    i dont know anyone who has a vectra
    but i will buy one asap hope it fixes it
    thanks again ill keep you posted
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 141000
    Quote Originally Posted by andrewl6527 View Post
    let us know mate keep us posted as i say 25 pounds i found was the cheapest
  1. vectra c 2,2 petrol sri
    By Asif in forum Engine & Drivetrain
    Last Post: 30th July 2011, 04:03
  2. 2.2 Petrol Vectra
    By robdd1 in forum Vectra C / Signum Car Chat
    Last Post: 29th December 2010, 12:03
  3. vectra 2.2 sri petrol
    By lordreeson in forum Engine & Drivetrain
    Last Post: 29th October 2010, 20:06
  4. Vectra sri 2.2 petrol
    By larrysSRI in forum Vectra C / Signum Car Chat
    Last Post: 22nd December 2009, 20:48
  5. Vectra sri 1.8 petrol - fsh 39k
    By arkhan78 in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 28th January 2009, 00:04
