Thread: Clutch and dmf help
    Jan 2012
    Somerset
    Default Clutch and dmf help
    Yes, another thread about it!
    Just a couple questions;
    If I order
    http://www.eurocarparts.com/ecp/c/Va...23bb00e&000069
    And
    http://www.eurocarparts.com/ecp/c/Va...db5a600&000134
    Do I need anything else? New bolts or anything.
    And how much should I be expecting for labour on top of this?
    Or does it work out cheaper to find somewhere to supply and fit?
    Regular Member kamar's Avatar
    bradford
    I've already got a dmf I'm going to buy a clutch with a new release bearing etc £220 and £100 labor
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    My internet in phone running too slow to see links. But need clutch pressure an friction plate, concentric slave cylinder, dmf, gearbox oil. You can get new bolts but I didn't just make sure torqued up properly.
    Ring around to compare what they say to supply an fit but it's about 6 hours labour.
    Jan 2012
    Somerset
    The links are for a luk clutch kit which I believe includes what you've mentioned and a Sachs flywheel. So labour cost isnt too bad then
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Double check for slave mate as it fitted a LUK clutch an flywheel to my v6 an needed to get CSC separate
    Jan 2012
    Somerset
    Says it comes with one so should be all good
    Regular Member ftm100's Avatar
    South Shields seagull sh*t town
    get them from here same company but cheaper
    http://www.carparts4less.co.uk
    Jan 2012
    Somerset
    Thanks for that!! I presume the clutch kit comes with a new release bearing!?
    yep
  1. clutch pedal really soft after new clutch
    Last Post: 3rd February 2013, 14:52
  2. Clutch slipping and loosing clutch/brake fluid
    By marty_b0y in forum Engine & Drivetrain
    Last Post: 31st May 2012, 00:18
  3. 3.2 GSI Clutch
    By cmowen in forum Engine & Drivetrain
    Last Post: 23rd May 2010, 13:31
  4. Need help with clutch rattle that dissapears when clutch depressed
    By leeroberts919 in forum Engine & Drivetrain
    Last Post: 14th July 2009, 11:56
