Results 1 to 10 of 22
Thread: Headlight Wahers
    Regular Member Ben Chiles's Avatar
    Feb 2011
    Redditch, West Midlands
    Default Headlight Wahers
    Vectra facelift, I've got headlight washer up front. Got the AFL headlights so the washers are on pop ups over of the front bumper.
    Questions is, i've never seen them work?! How do you get them to operate, as they don't work when i do the windscreen?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Is there some sort of Headlight washer Epidemic today? So many threads about them.
    Btw can you hear the pump going? If you not the pump may have gone. The facelift washers need water pressure to left the jets out of the bumper.
    Regular Member Angel1368's Avatar
    Mar 2012
    liverpool
    17 Post(s)
    Trim : VXR
    Engine : 2.8 V6 turbo
    Mileage : 44,000
    maybe have lights turned on when you wash windscreen
    Glasgow
    Yip headlights turned on and wash your windscreen, if they dont work the first place to check is the fuse. Its listed in your manual and it pops during freezing weather when the washers are frozen.
    VIP-Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 Vtec
    Mileage : 64500
    Yup headlights on(works on sidelights too)and pull the windscreen washers. Fuse for the facelift is number 13, 30 amp.
    Feb 2011
    Quote Originally Posted by GazCDTI150 View Post
    Are the headlight washers on the same pump as the windscreen washers?! Cause the windscreen washers are working fine??? Can hear the pump working but yeah the windscreens getting covered by that point.
    Quote Originally Posted by Angel1368 View Post
    Drive everywhere with the lights on, so 9/10 times i wash the screen the lights are on, the few times i've tried it on the drive also had the lights on
    Quote Originally Posted by byebyeitsagsi View Post
    So by that i take it every time you wash the windscreen the headlight washers are meant to do the lights, not like every 4 times you wash the screen the lights get washed once kinda thing? Right, fuse for the headlight washers, i'll try and find it in the manual. Thanks for the info, got a place to start
    Feb 2011
    Awesome cheers pal, saved me the light reading now :-) Shall let you guys know if the fuse is good or not lol
    Don't work off the pre-facelift Haynes manual either - the fuse numbers in the facelift are different...
    Took me ages to find out why my headlight washers weren't working...
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 Vtec
    Mileage : 64500
    Quote Originally Posted by Ben Chiles View Post
    No its a seperate, much bigger pump.
    No problems.
    Quote Originally Posted by Penfold101 View Post
    Yes Preface its position 14, facelift position 13. It actually may be a half can/ full can thing. So if anyone has a full can preface can you check your manual please and get back to us.
    Feb 2011
    Well had five minutes earlier so went out and had a quick look in the cabin fuse compartment and sure enough no wonder they weren't working...
    Think the fuse is meant to be under the red one??? Yet doesn't even seem to be the contacts there?!
    Another quick question, it's an estate so regarding the dreaded check guard rear window alarm sensors. Had the alarm going off randomly a week or so ago. So after advice on here checked the wires that run round the boot windows and sure enough, there's one with a break in the run, so i've unplugged that one side and get the guard check message on the info display whenever i start the car. Question is if i pull the fuse in the boot compartment, number 23 detailed as "glass breakage sensor" and plug the side back in that i had previously pulled out, will i one, have the alarm going off randomly again and two, have any display errors when starting the car?
  1. headlight help pleaSE
    By jimmywhu in forum Electrical & ICE (including SatNav)
    Last Post: 21st December 2012, 17:50
  2. Headlight
    By mageamind1979 in forum Bodywork & Interior
    Last Post: 7th January 2012, 21:08
  3. DIY headlight mod day!!!!!
    By bertbuckie1 in forum Styling
    Last Post: 4th January 2011, 00:07
  4. Headlight mod .. need help
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 28th October 2007, 19:18
