Results 1 to 10 of 22
Thread: ECU is knackered
    Jul 2009
    Leicester
    Default ECU is knackered
    Just had a mechanic out to diagnose a fault on my vectra 2.0dti 2004. Originally the glow plug relay was removed and replaced and since that I have been unable to start the car. There is power to dash by turning the key does not start vehicle. The tech was unable to connect to ecu to retrieve fault codes.
    My question is where can I find the ECU and how much would it cost roughly to replace?
    Administrator plasma's Avatar
    On the Forum
    399 Post(s)
    Engine : 150
    Mileage : 74000
    just because he cant connect doesnt necessarily mean is knackered.. Did he check supply to the ECU, did he check the canbus lines to it to make sure they are ok? All checks like this need to be done first.. probably the answer is no as the plugs on the ECU are a pig to get to.
    btw, the ECU is part of the diesel pump, quite a bit of stripping down to get to the ECU/Pump... FLOB is doing the same thing at the moment.
    IF the ECU can be removed from the pump then its about £200 for a repair, if it has to be removed as one unit then your looking at strip down labour to remove the timing chain to remove it.
    Its located front left of the engine, just follow the metal diesel pipe lines to it.
    Jul 2009
    Leicester
    Are these something I can check myself?
    On the Forum
    399 Post(s)
    Engine : 150
    Mileage : 74000
    not unless you know what your doing unfortunately
    Regular Member benny's Avatar
    Feb 2006
    dudley
    Does the car actually crank .?
    Jul 2009
    Leicester
    nope, turn the key and its dead, strange thing is i have no glow plug light on. But cant read codes, cus OBDII will not talk to ecu
    Sep 2010
    Right here, right now.
    6 Post(s)
    Trim : SRI
    Engine : 3.0 V6 CDTI
    Strange and simple question, is it the right ECU he has put on? Can't you put you old one back on to check that you can connect to it over the can-bus system?
    Feb 2006
    dudley
    Needs to see a tech 2 / 3 ... Needs a module ecu presence check what ever ecu / module is missing that ecu needs its feeds and earths checking and then possibly that ecu is faulty / has wireing problems .... Don't just jump in the deep end and think its a big fault think simple
    On the Forum
    399 Post(s)
    Engine : 150
    Mileage : 74000
    Quote Originally Posted by lee_umney View Post
    he changed the glow plug relay not the ecu,
    Jul 2009
    Leicester
    Is there any one with tech 2/3 in the Leicester area willing to help me out? If there other diagnostic kits won't talk to ECU, won't it be the same with tech 2/3?
  1. My DPF is knackered! Help!
    By rockafella8587 in forum Engine & Drivetrain
    Last Post: 6th March 2012, 15:46
  2. Think my key is knackered
    By vectrasri20t in forum Bodywork & Interior
    Last Post: 26th February 2010, 12:01
  3. Im knackered.....
    By PAULMAC77 in forum General Chat
    Last Post: 14th April 2009, 09:51
  4. I'm Knackered
    By AJA in forum Comedy & Humour
    Last Post: 13th February 2006, 10:45
