Results 1 to 10 of 13
Thread: Battery light.
    Mar 2011
    newcastle upon tyne
    Default Battery light.
    Just wondering if anyone knows why my battery light comes on and stays on sometimes.The car is running fine and starts first time, everything electrical working ok.57 plate 55k.
    Nov 2009
    N/A
    Quote Originally Posted by don1966 View Post
    Battery lights are normally a sign of a failing charging system.... If you have access to a multimeter, check the voltage across the battery with it running, should read around 14v
    Mar 2011
    newcastle upon tyne
    Ok thanks, will check the voltage.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Your alternator's knackered
    ---Sent from my iPhone 4 using Tapatalk
    Mar 2011
    newcastle upon tyne
    Angry
    Thanks Tony, thought a alternator would last more than 55k,have to have a trip to clencoe autos in that case.
    Regular Member carl78's Avatar
    Mar 2012
    Telford
    defo the alternator going.My first one went at 38k then again at 42k number three is still going strong now on 49k so they can go before 55k good luck with it
    Assuming your profile is correct, that's good going for a 2007MY
    The typical life for any component can be up to 3 years and so 5 years is acceptable
    Mileage doesn't really come into it for alternators, the usual cause of failure at low mileage is just that, short trips with lots of engine starting over time
    An alternator can last much longer on long trips with fewer engine starts over time
    I can typically get 180K miles / 7 years before the alternator gives up the ghost
    Mar 2011
    newcastle upon tyne
    Yes my profile is right car is 5 years old.do you know the price of one fitted?
    Apr 2012
    Nottinghamshire
    Yes that is certainly the alternator. Sort it quickly as suddenly your power steering goes. Are the lights in the central consol still working? They go to. You are running on battery, get a bosch alt fitted, the originals fitted are rubbish.
    Regular Member dahmich's Avatar
    cwmbran
    mines coming on, staying on for 10mins, then going off if i stop the car and re-start, all other electrics ok, battery showing really good voltage, but i think i have a problem with my egr, dont think the two are connected?
  1. Replies: 4
    Last Post: 18th August 2012, 08:58
  2. Replies: 17
    Last Post: 16th August 2012, 10:07
  3. Battery Light ON - 14.1 volts at battery
    By snapsnap in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2011, 13:55
  4. battery light on along with spanner through car light
    By conny in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2011, 13:45
  5. Battery light on, 14.4V at the battery!
    By Saulty in forum Electrical & ICE (including SatNav)
    Last Post: 16th January 2011, 23:29
