Thread: CD30 - Buttons Suddenly Not Functioning??
    North East
    Default CD30 - Buttons Suddenly Not Functioning??
    I have been out in my car today and noticed that some of CD30 stereo buttons have stopped working properly. The display has stopped showing CD track information and just shows the avg mpg info at the moment even tho the cd is still playing. I can change to radio but the display doesn't show any radio station info i.e. i have no idea which station is playing. I have also noticed that the steering wheel functions on the right hand side no longer work (vol up/down & track change). I can also no longer reset the trip as the buttons dont seem to correspond to the display. The left hand side steering wheel function still seems to change the display to mpg, inst fuel consumption etc but I cannot reset anything.
    Has anyone else had this and is there a fix?
    North East
    Anyone..
    Am I best taking it to a VX dealer to look at and if so is there usually a standard charge just for looking? Roughly how much?
    Any help/advice would be gratefully appreciated.
    Michael
    Engine : 1.9 CDTi
    Try taking the unit out and check its plugged in ok first.
    North East
    Quote Originally Posted by lee gsi View Post
    I did take the unit out and there was 1 iso type plug in the back and 1 single black wire that could have been the arial wire? I didn't remove either of them, do you think it's worth it? Should there be any other wires in the back of the unit?
    Full Member Robsey's Avatar
    North East Cheshire
    21 Post(s)
    Trim : Energy
    Mileage : 131,000
    First thing to do is completely unplug the head-unit for half an hour or so.
    Reconnect, and see if that has "refreshed" the head-unit electronics.
    CD30 can be a bit niggly anyway - extreme units turn themselves back on etc.
    If that don't work, the do the same with the display.
    If this still doesn't sort it, then check fuses in the end of the dash..
    Fuses 1, 12, 17 and 26.
    now then if none of this sorts it, lets consider ............
    If the radio is working, and the display is working,
    but there is no communication between radio and display, then I would look at the two communication (Mid speed CAN) wires that link the two units
    head-unit pin 9 (green) goes to display pin 20
    Head unit pin 10 (white) goes to display pin 19
    if needs be, try fitting temporary "jumper" wires to bridge these links.
    If none of this sorts it, then you may need to replace one of the components, or geta matched pair from ebay etc...
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Same happened to mine. I disconnected the car battery for 5 mins. All sorted :thumb;
    ---Sent from my iPhone 4 using Tapatalk
  1. pm`s just suddenly gone missing
    By andy.l in forum General Chat
    Last Post: 14th May 2012, 21:08
  2. non functioning elec mirrors
    By Papa Lazaroo in forum Vectra C / Signum Car Chat
    Last Post: 30th November 2010, 14:03
  3. CD 70 Sat Nav Suddenly can't locate car!!
    By S16XTY in forum Electrical & ICE (including SatNav)
    Last Post: 6th July 2010, 17:59
  4. Mirrors suddenly fell off
    By Signumandneil in forum Bodywork & Interior
    Last Post: 15th May 2010, 10:28
cd30 buttons not working
https:www.vectra-c.comforumshowthread.php162799-CD30-Buttons-Suddenly-Not-Functioning
vauxhall astra radio buttons not working
zafira b cd30 not lighting up and no display
astra h cd30 buttons not working
radio button on vauxhall insignia not working
opel insignia 2009 buttons wont work
vauxhall astra cd30 not working
vauxhall tigra cd30 steering controls not working
cd30 buttons not working but steering wheel controls do
astra h cd30 cant change channelastra h infotainment buttons not workingopel vectra c cd player not turning oncan you reset vauxhall cd30cd30 radio not respondingvauxhall vectra radio volume not workingvectra c steering radio control cd30 fixvauxhall vectra cd30 control reprogram cd30 vectravauxhall corsa factory radio buttons doesnt workzafira b radio buttons not workingCd30 mp3 stuck on Channelastra 2006 radio buttons not workingcd30 resetcd30 program radio buttons
