Thread: slight Loss of power 1.9 cdti 2006
    Regular Member leedrummond's Avatar
    Apr 2011
    Stoke On Trent
    Trim : 120 Exclusiv
    Engine : 1.9 CDTI 8v
    Mileage : 150,000
    Exclamation slight Loss of power 1.9 cdti 2006
    Hi, i am looking for some possible answer / solution to a problem with my dads car
    There seems to be loss of power which i think is so noticable after owning the same car.
    Very noticable when i just took it around the block up hill in second, really struggled felt like i was in wrong gear (4th) nearly had to go up in 1st.
    Could this be a clutch issue or valves leaking ?
    any help appreciated so we can start to fix the problem
    Lee
    Regular Member DeJohnny's Avatar
    Jun 2011
    belgium
    Have you checked the EGR? Disconnect it for a while and see if its better again, if so buy new egr or fit blanking plate
    gwent
    It also could be the swirl flap not opening all the way and not closing fully as my car has lost some of it's power but I did have a fault code and did the swirl bar actuator test. I now ordered a new inlet manifold and all the gaskets and new actuator motor all I need now is to sort out finding a garage to fit it
    Apr 2011
    Stoke On Trent
    Trim : 120 Exclusiv
    Mileage : 150,000
    cheers guys :-) will have a closer look tomorow then and see if its any of these
    Apr 2011
    Stoke On Trent
    Trim : 120 Exclusiv
    Mileage : 150,000
    Thank you all that seemed to have fixed it and my dad said his car is getting better by the day. Someone told him to resound it too but he can only do that in 1st gear
  1. CDTI 150 slight coolant loss
    By AntSSSS in forum Vectra C / Signum Troubleshooting
    Last Post: 19th July 2011, 21:34
  2. Slight Misfire & (Intermittent) No Power When Engine's Cold (1.9 CDTI 150)
    By DanR in forum Vectra C / Signum Troubleshooting
    Last Post: 11th March 2011, 21:13
  3. Spanner light and slight loss of power 2.2dti
    By nickd_m in forum Engine & Drivetrain
    Last Post: 10th November 2008, 23:28
  4. loss of power 150 cdti
    By SRI-150 in forum Engine & Drivetrain
    Last Post: 17th May 2008, 14:24
  5. loss of power 1.9 CDTi
    By ALD in forum Engine & Drivetrain
    Last Post: 5th January 2007, 16:25
