Thread: Fault Code P0093 Rail Pressure Range/performance??
    Regular Member MarkV6cdti's Avatar
    Sep 2011
    Northampton
    Vehicle : Vauxhall Signum
    Trim : Deselite :-)
    Engine : 3.0 V6 CDTI
    Mileage : 130,000
    Talking Fault Code P0093 Rail Pressure Range/performance??
    Hi all,
    I've just had my siggy plugged in this morning as when it's warmed up and I am stationary the engine cuts out. It restarts fine but sometimes with the T/C light on. The fault code read P0093, any ideas would be greatly appreciated please?
    There were no other fault codes as he did all checks.
    My VXR front bumper is going on this week..............
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Change the fuel filter and see where it takes you
    Regular Member wayne1972's Avatar
    Apr 2012
    skegness
    Default re signum
    Hi Mate,
    Let me know how you get on with your problem. I have the same car as yourself and similar issue, car cuts out when revs are high and triggers in limp mode. A high pressure rail sensor from vaux is £281 plus vat If the fuel filter fixes your problem also let me know. All the best
    PS Like to see the finished vx bumper
    Apr 2012
    skegness
    Default re fuel filter
    Quote Originally Posted by Celes View Post
    Hi mate,
    Has changing fuel filter worked in the past? I have a similar issue
    Sep 2011
    Northampton
    Trim : Deselite :-)
    Mileage : 130,000
    This the 1st time this problems occurred so I'm only going off advice and see if it fixes the problem. Can't do it until Saturday when my car comes back with a facelift.
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Quote Originally Posted by wayne1972 View Post
    Hi mate,
    It helped once, but in a year the SCV were completely blocked.
    Sep 2011
    Northampton
    Trim : Deselite :-)
    Mileage : 130,000
    After changing the fuel filter the car has run like a dream....... up until last week where it's now started doing the same again.
    Its going in to the garage next week t get checked over. I've done some research and I do believe its something to do with the SCV or a sensor on the fuel rail.
    I will keep you updated with the progress.
    Also here's a picture of my VXR bumper all painted and fitted!!
  1. P0190 Rail Pressure Range / Performance.
    By bobby_rstevens in forum Engine & Drivetrain
    Last Post: 7th July 2011, 18:38
  2. P0093- Fuel system leak serious fault
    By s2yob in forum Vectra C / Signum Car Chat
    Last Post: 20th June 2011, 19:56
  3. p0090 fault rail pressure control
    By kamar in forum Engine & Drivetrain
    Last Post: 15th March 2010, 14:11
  4. Fuel Rail Pressure sensor
    By RobW in forum Engine & Drivetrain
    Last Post: 3rd December 2009, 16:55
opel p0093
zafira diesel fault code p0093
opel 0500fb1
https:www.vectra-c.comforumshowthread.php162781-Fault-Code-P0093-Rail-Pressure-Range-performance
p0093 opel signum 3.0
0093 kod opel astra
opel zafira p0093
Opel P0093 3.0cdti
vauxhall zafira diesel a17dth fault code p0093
zafira fault code p0093
p0093 vectra c cdti v6
p0093 astra
P0093-0
VAUXHALL P0093
vauxhall astra fault code p0093
vauxhall 3.0 v6 diesel p0093
p0093 opel
range performance opel astra
vectra c 2007 3.0 v6 cdti rail switch
vectra c fault code 0500fb1
opel astra c fault message
opel astra p0093
How to diagnose error p0093
p0093 and limp mode leak vauxhall
p0093 vauxhall
