Results 1 to 10 of 22
Thread: Fuel filter. gave up!
    Regular Member GoldenWonder's Avatar
    Durham
    Default Fuel filter. gave up!
    I spent the last hour under the car trying to change the fuel filter on my petrol turbo. I had to give up as I just couldnt get the fuel lines to come off the filter! I guess you have to push the blue clips in on each side at the same time and pull apart? But mine wouldn't move and I didn't want to damage the connectors
    Access is a bit tricky so is there a trick or tool to make doing this easy on a narrow and steep driveway?!
    Or maybe my diy days are coming to an end......
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Try using a small flat blade screwdriver at back of connector to press it down
    Durham
    I tried but its hard to see what youre doing and it still seems stuck. I guess you need to be right under the car to do it. I tried to do this on our drive but I suppose ramps or pit are the way to go.
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    I've done plenty just on a jack.
    Did have a Zafira which was a ****** to get the filter off and ended up with a snapped pipe :'( D'oh
    Had to ****** drop fuel tank to fit new one.
    Regular Member poves's Avatar
    lancashire
    I snapped a fuel line retainer clip yesterday on a chevrolet kalos , what a nightmare .
    I could'nt even get a replacement part , so had to plumb a new section in and do it the old fashioned way .
    I was a little dubious whether it would hold out , but I used inline connectors , then wrapped it in pressure tape and then 2 jubilees on each joint .
    Worked a treat .
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Did mine the other week, me with two screwdrivers pushing the clip in either side while Amy reached under and pulled the filter off, each end straight off in seconds. You can buy special tools to do them but you don't need them (a third hand is useful though ).
    gwent
    Talking
    You can buy set of tools there are three in a pack about £16 from machine mart the part number is CHT441
    Durham
    Yeah I think and extra hand would have helped!
    I might buy a tool - its cheaper than paying for a replacement conenctor when I snap it off with my screwdrivers!
    Durham
    Just found a silverline set on ebay for £9.97 delivered - 3 pairs so I've ordered those!
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Might not work that well I've got a set an still end up using a small flat blade
  1. Replies: 19
    Last Post: 30th May 2012, 15:53
  2. How do i remove the fuel lines from 3.2 fuel filter...?
    By killer_bunny in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2010, 23:07
  3. Fuel filter on a 3.2v6
    By andyxedos in forum Vectra C / Signum Troubleshooting
    Last Post: 24th February 2010, 20:31
  4. fuel filter
    By shy_stag in forum Vectra C / Signum Car Chat
    Last Post: 26th April 2008, 09:51
  5. Oil Filter location and Fuel Filter
    By trickydickySRI in forum Vectra C / Signum Car Chat
    Last Post: 26th July 2006, 10:31
