Thread: Brake light fault indicator.
    Apr 2012
    Hartlepool
    Default Brake light fault indicator.
    Can anyone help. My car is telling me their is a fault with my brake lights but when i checked them there working fine.
    Regular Member John Bishop's Avatar
    Oct 2010
    Could be that it is sensing it is about to fail
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Mine has been telling me to check my reversing light for the past month - keep checking it and its ok - appreciate it could be indicating the bulb is on the way out but loathe to change it as means taking the trim off the tailgate (its an estate) to change it and its a pain getting it off
    Oct 2010
    Quote Originally Posted by alcutler View Post
    Don't I know it. Stupid design
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Quote Originally Posted by bishbang View Post
    I've just about lost/broke every plastic clip on the trim and ended up using self tappers to hold it in place - you'd have thought they would have put a couple of removable hatch covers to allow access to the lights in the tailgate.
    Apr 2012
    Hartlepool
    The indicator only comes on every so often
    Full Member
    Dec 2010
    London
    Engine : Z18XER
    As stated above you have a bulb failing
    The filament breaks and then welds itself together
    The canbus system detects a change in resistance and puts on bulb failure warning light
  1. brake light fault (confused)
    By frigosolver in forum Electrical & ICE (including SatNav)
    Last Post: 21st January 2012, 15:34
  2. Brake light fault:-possible cure?
    By pilgrim in forum Electrical & ICE (including SatNav)
    Last Post: 9th June 2011, 09:20
  3. Brake Light fault
    By interceptor-jamie in forum Electrical & ICE (including SatNav)
    Last Post: 23rd April 2011, 21:05
  4. strange brake light fault
    By Bethan39 in forum Electrical & ICE (including SatNav)
    Last Post: 8th May 2010, 14:55
  5. Hand brake indicator light
    By Padster72 in forum Electrical & ICE (including SatNav)
    Last Post: 6th May 2008, 21:15
