Hi all,
i'd check the "how to" section but was not posted. Anyway, was thinking to change to some white light but wonder how do i remove the map reading light cluster. Hope you guy dont find this too stupid to answer.
Tks in advance.
Hi all,
Tks in advance.
If your just changing bulbs you only have to remove the glass panel by popping it off and then the bulbs should just pull out. Use a small screwdiver with some cloth round it to remove cover.
Becareful as the lights can also get hot. Best to do it in full daylight not ith the interiour lights on!
If I remember correctly you have to remoive the glass bit to take the binnacle down from the roof anyway.. there are a couple of screws behind the glass and a couple behind the sunglass holder or blanking plate.
As already said, if you are just changing the bulbs, you can do it with the light still in the roof.
guys, tks for the prompt replies.....the vec B one is so easy to remove as it was just a smaller piece, the new vec C come with a big one, (well, everyhing grow in size...lol. ) so now i know is just have to pop in down....will try it soon. tks.
