Results 1 to 10 of 18
Thread: Help needed on sub woofer set up please....
    Regular Member ridgers84's Avatar
    Jan 2012
    Derby
    Default Help needed on sub woofer set up please....
    Right. Installed my sub today. It's looking good. I just need to tidy up the wires etc.
    It's sounding good... But it could be better....
    I've got my HPF on my head unit set at 125hz and the crossover on the sub set at around 125hz also - is this correct? The gain is on half way. It's very loud and bassy and over powering but not as punchy as I'd like. I have two ports with removable plugs, if I remove the plugs will that make it more punchy? the sub level in my head unit is on normal.
    Any help appreciated guys
    Jan 2012
    Derby
    Ooo... Forgot to add, I'm getting a bit of interference coming through the sub. It's like a clicking sound. Any ideas?
    Dec 2011
    Seaham
    Trying PM ing Ian Highlander, he seems to be up on car-fi
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Depends entirely on the setup and your head unit. I generally set the crossover point for subs at about 120hz so you're about right there. But my head unit has a dedicated sub pre output for the sub amps so all my high pass filters are off meaning the speakers in the doors are getting the full range they can cope with which gives a much fuller sound.
    Jan 2012
    Derby
    Cheers Ian. If I turn my filters off I'll have too much bass going through the door speakers and they'll just distort. They've got a punchy mid though! Any ideas what could be causing interference?
    Regular Member Knight Rider's Avatar
    Apr 2008
    Motherwell
    Vehicle : Vectra C SRi 1.8vvti
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    Is your power cables and speaker cables seperate ie not running along side each other. This could cause interference if they are.
    Regular Member 0114NIGEL0114's Avatar
    SHEFFIELD
    Been looking about to thinking of getting 2x15s there 2000 watts each min 700 rms max 1000 rms what amp do I need I know I need a mono block amp Just looked at a sound storm ev3000d amp not sure though
    Regular Member Guss's Avatar
    Aug 2011
    West Malling, Kent
    Hi ridgers
    your clicking sound is your amp turning on and off away around it is to change your earth, the closer to the amp the better.
    Your sub is cable of putting out much lower than 125 htz, it you can drop it as low as 30 or 40 it will be better, it will push out thundering baxe you feel more than you here.
    your mids will add the puchy bass. If you can drop in a power capacitor 2 million farad variety and your sub will run smoother as it can delivert power quicker than your car battery and ease your alternator which will be put under strain from your amp...
    Jan 2012
    Derby
    Quote Originally Posted by 0114NIGEL0114 View Post
    Oi get your own thread! Lol
    Jan 2012
    Derby
    Quote Originally Posted by BLACK KNIGHT View Post
    Hmmm yeah they are, I've got the power cable, remote and output cable all running down the passenger side. Do they need separating then?
  1. help needed
    By justin32 in forum Engine & Drivetrain
    Last Post: 31st March 2012, 21:53
  2. Help needed
    By Robward27 in forum Suspension, Wheels & Brakes
    Last Post: 22nd March 2009, 01:31
  3. help needed
    By steven_armit in forum General Chat
    Last Post: 16th March 2009, 20:05
  4. adding a sub woofer to standard cd30 head unit
    By pogo in forum Electrical & ICE (including SatNav)
    Last Post: 13th July 2007, 20:53
