Thread: levelling motor fitting help
    Regular Member hairy31's Avatar
    Jun 2009
    bradford
    confused levelling motor fitting help
    well got my motors today but...........after 30 mins i gave up, how the hell do you get the ball joint in the clamp, and do you have adjuster set to 1 if your putting in
    Leeds
    Vehicle : Insignia
    Trim : VX-Line
    Engine : BiTurbo
    Gently ease the internal of the headlight down wards whilst holding the motor ball joint under the groove.. That way the ball joint will connect with the clamp.
    May 2008
    Tyneside
    This link may help, look at post 3 & 5 with picture.
    http://www.vectra-c.com/forum/showthread.php?t=155119
    Jun 2009
    bradford
    Thanks guys , I will have another go, do you have the adjuster on zero before fitting
    May 2008
    Tyneside
    It doesn't matter what setting the level is, it sorts itself out when the motor is fixed in position.
    Hanging Heaton / Batley
    21 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Should just bring the stuff tomo
    Jun 2009
    bradford
    Quote Originally Posted by leemarksmith View Post
    U reckon mate , not a bad idea actually
    21 Post(s)
    Mileage : 110k
    Quote Originally Posted by hairy31 View Post
    Yeah, sure others will be doing other stuff too, might as well.
    I'm taking my tools and wiring kit incase anyone needs a hand with owt...
    Regular Member Mads's Avatar
    Ipswich,.UK
    oh no this happened to me, when i was trying to change headlight bulb i took the motor out by mistake, took me ages to get it back in but unsure if its in right, it happened on the passenger side, what do you think, is it a bit high or looks ok?
    anyway to check head light pattern/height?
    Ipswich,.UK
    forgot to add that both lights move up and down together so im guessing if it wasnt in right it wouldnt move????
    sorry to jump on your thread hairy31, you just reminded me
  1. Fitting a starter motor - can someone please explain how2
    By wingz123 in forum Engine & Drivetrain
    Last Post: 30th May 2011, 14:57
  2. Possible self levelling for the Vectra????
    By raymie.d in forum Electrical & ICE (including SatNav)
    Last Post: 7th November 2010, 19:26
  3. Retro fitting xenon auto levelling sensors
    By lofty in forum Vectra C / Signum Car Chat
    Last Post: 29th April 2010, 10:27
  4. levelling the suspension?
    By jamesr in forum Suspension, Wheels & Brakes
    Last Post: 14th September 2008, 21:37
  5. Xenon's weren't self levelling.
    By SirGSi in forum Electrical & ICE (including SatNav)
    Last Post: 20th September 2005, 14:38
