Results 1 to 10 of 13
Thread: vectra top mount bearing question
    Feb 2012
    uk
    Default vectra top mount bearing question
    my vectra top mount drivers side is making a noise when you move the steering back and forth do i need to replace all of the bearing or part of it .you can both parts off the internet separately you can get the strut mount and the bearing for £38 do i need anything else .
    Feb 2012
    uk
    Jun 2009
    South Coast
    Vehicle : Vectra, Signum & Insignia
    Engine : Z18XE,Z19DTH,Z20NET,
    you would just need the new bearing not the mount... I did change my mounts as i snapped a stud off in one of them, i then painted up the new mounts as they do corrode before installing them but i would not think you need to replace yours.
    The wifes vec show car is currently being stripped for parts before i scrap it, keep an eye on the sales section.. https://www.vectra-c.com/forum/garage_vehicle.php?do=view_vehicle&id=709
    South east
    Why not buy this instead, seems better value and a known brand:
    http://www.carparts4less.co.uk/cp4l/...61c8915&000872
    11 Post(s)
    Quote Originally Posted by borderman932 View Post
    my vectra top mount drivers side is making a noise when you move the steering back and forth .
    I thought so with mine too. Turned out just to be small amounts of grit had got between the lower cup and suspension spring stopping it seating properly on the lower cup face. Garage just lifted the spring up slightly with a screwdriver and blew the debris out with an air line, resulting in no more noise.
    Nov 2010
    East Midlands
    Trim : design
    Quote Originally Posted by Rebellion View Post
    That's the mount - I think its the bearing itself he needs - I repaired one of my bearings that was a bit rough when turning it. I had taken it off to replace the spring - managed to take it apart cleaned the ball bearings and the tracks they ran in - with a good greasing and its been fine since - worth having a look at it before replacing
    South east
    Quote Originally Posted by alcutler View Post
    No, I've just had a webchat with ECP who run that site and they reckon it comes with the bearing as well.
    Kildary, Highland
    I got Febi Bilstein ones off eBay, bearing only, dead easy to fit - you don't need the mount
    Regular Member david-bell's Avatar
    eastlothian scotland
    Vehicle : vectra vxr
    Trim : vxr
    Engine : 2.8 v6 turbo
    Mileage : 31000
    I had the same issue as you have! Ireplaced mines with these http://www.eurocarparts.com/suspension-mounting and my mounts were fine I just replaced he bearing hth
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Quote Originally Posted by david-bell View Post
    Does the ECP part include the bearing and topmount as one?
  1. question about front top mount components?
    By MCD in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2011, 14:41
  2. Can top mount bearing or arb bushes rattle?
    Last Post: 18th February 2011, 20:40
  3. Top mount bearing?
    By goafer in forum Suspension, Wheels & Brakes
    Last Post: 6th June 2010, 08:57
  4. Wheel Bearing Question ???
    By Cilldara1 in forum Engine & Drivetrain
    Last Post: 8th October 2007, 17:03
  5. Astra G Question - Wheel Bearing
    By VectraMat in forum Vectra C / Signum Car Chat
    Last Post: 23rd September 2007, 21:34
vectra c top mount
vectra c top mount bearing
vauxhall vectra vxr top mount bearings
vauxhall vectra suspension top mount
vectra c top strut bearing
