Thread: Oil and fuel filter 1.9 cdti 150
    Oct 2010
    bonnie scotland
    Default Oil and fuel filter 1.9 cdti 150
    What would you think is the going rate at a back street garage for getting oil filter and a fuel filter changed
    Many thanks
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Personally I would get he parts yourself from VX... and then just get them to 'do' it.
    Use GM 5w30 Fully Synth Dexos2 oil and genuine filter.
    Suspect a garage would charge 1/2 hr rate if reasonable - or 1hr if thats there min charge..
    Or - do it yourself mate if you can ?
    Oct 2010
    bonnie scotland
    Well I could do it but I can't really be bothered I was told 90 from a local garage
    Nov 2010
    East Midlands
    Trim : design
    If you've got 90 quid to spend let them do it - as said above its an easy job to do, you'll save yourself £50 and most of all you will know it has been done and done properly. With the money saved you can buy yourself some decent tools to do it again next time
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Vehicle : Vectra C estate
    Trim : SRI
    Mileage : 79000
    garages around here do oil and filter change for £35ish with fuel filter on top of that id say another £10-£15 extra, bearing in mind you dont really know what type of quality the oil is.
    As above suggests get the stuff yourself from vx, then you know for sure whats going in
    Oct 2010
    bonnie scotland
    Cheers guys
    Jul 2009
    Yorkshire
    Did mine last weekend, but also included the air filter. The genuine GM air, oil and diesel filters cost £34 delivered (the stealers wanted £75!!!!), plus I also got 5-ltrs of genuine GM 5/30synthetic oil for £19.50 delivered. I have to admit, I also needed to replace the sump plug (£6 from stealers) as it had been rounded off when last fitted. Also needed to borrow a 32mm socket from my mate to undo the filter case. It took under an hour to do including jacking car up etc.
    Oct 2010
    bonnie scotland
    Hi where did you get the parts from bud
    Jul 2009
    Yorkshire
    Quote Originally Posted by chay6684 View Post
    Got the full service kit off Fleabay from a genuine VX dealer, seller name is 'waltercbrigg'. It was actually £35 (not £34 like I thought) plus £5 delivery.
    The oil came off Fleabay too, seller name is 'davidchamps1964', and cost £19.95 for 5-ltrs genunie GM oil.
    Oct 2010
    bonnie scotland
    cheers
  1. Where is fuel filter on 3.0 V6 cdti
    By s2yob in forum Vectra C / Signum Car Chat
    Last Post: 23rd June 2011, 17:29
  2. fuel filter cdti 150 .
    By dave r in forum Engine & Drivetrain
    Last Post: 14th April 2010, 20:22
  3. cdti fuel filter
    By cockney16v in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2010, 19:23
  4. CDTI Fuel filter
    By crgv6 in forum Engine & Drivetrain
    Last Post: 26th November 2009, 21:27
  5. Cdti Fuel Filter
    Last Post: 11th June 2008, 22:14
