Page 1 of 6 123 ... LastLast
Results 1 to 10 of 58
Thread: air box modification
    Regular Member davedave's Avatar
    Apr 2012
    manchester
    Default air box modification
    have a vectra turbo what mods can you do to the air box
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Drill it and remove the extra bit of plastic. Have a look at ian highlanders old threads
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Removing the bottom plastic "trumpet" is what's referred to on here as "the airbox mod" and is done by pretty much everyone.
    It's not worth drilling the air box unless you've had the car re-mapped. I did mine as one of the rolling roads I used recommended it because it was struggling to get enough air at the highest revs, drilling mine cured that, but it only makes a difference at the top end of the rev scale and only if you're running a remap over 200bhp.
    This is mine but as said this will give you NO benefit if you're not running quite a bit more power than standard and even if you are, it only helps the top end revs nothing else.
    Jul 2011
    peterborough
    ive also found not meant to cut top trumpet part out, oops
    Ely, Cambridgeshire
    61 Post(s)
    Year : 2010
    Yup don't remove the top one it's there to smooth out the airflow into the MAF.
    Regular Member Gubmint Agent's Avatar
    Feb 2011
    Feels a lot like Kathmandu.
    Trim : Sri
    Engine : 2.2 Direct
    Doesn't drilling the bottom of the airbox like that not allowed grotty unfiltered air straight into the engine? Wouldn't drilling the top of the airbox (ie, above the filter) be better? I've always wondered...
    Ely, Cambridgeshire
    61 Post(s)
    Year : 2010
    No fella, the air gets sucked from the outside through the tube in the bottom (next to where I've drilled the holes) then goes through the filter to the intake on the MAF in the top of the air box, so all air is filtered
    Jul 2011
    peterborough
    Quote Originally Posted by Ian-Highlander View Post
    dont suppose you got dimensions of your top tube at all do you, as found couple in breakers from other vauxhalls & was just going to glue 1 in situ to hope it helps
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    Turbo engine......I introduced an extra cold air feed into my air box direct from my front grill. not from the engine bay where heat from the engine can be drawn into the air box.
    Take a look at this thread. It works well with my engine which is also turbo forced induction engine. Cold is the way to go!http://www.vectra-c.com/forum/showthread.php?t=145973
    Ely, Cambridgeshire
    61 Post(s)
    Year : 2010
    Quote Originally Posted by DTI-Steve View Post
    I used to think exactly the same and there's no arguing with the fact cold air is denser and therefore better, but with the air moving round the engine at speed from outside the car (underneath and sides) the heat soak is going to be minimal and all air from the turbo goes through the intercooler before it hits the inlet manifold anyway.
    The above mod on my airbox definitely did the job that's for sure but as I said it was only for high end revs anyway, the standard airbox is more than adequate for most of the rev range even with a tuned car.
  1. Need Help in modification
    By my834 in forum Electrical & ICE (including SatNav)
    Last Post: 20th June 2010, 01:27
  2. New modification..........
    By mc_orion in forum Vectra C / Signum Car Chat
    Last Post: 18th November 2008, 15:37
  3. 1st Modification
    By Gregg in forum Quick Photo Album
    Last Post: 15th November 2007, 16:51
  4. Next modification anyone??
    By j13hdb in forum Comedy & Humour
    Last Post: 13th November 2007, 16:15
  5. modification to air box????
    By mbonnick in forum Vectra C / Signum Car Chat
    Last Post: 29th July 2006, 15:42
drilling vectra c direct airbox
vectra dti airbox mod
vxr drill the airbox after remap
insigina vxr remap drilk airbox
how to get cold air feed on vectra c 2.2 direct
saab 9.3 drilled airbox
vectra c drilled airbox
drill holes in airbox vectra c
