Thread: whine from front passenger side
    Regular Member skip85's Avatar
    Wiltshire
    Vehicle : vectra c estate
    Engine : 1.9 cdti 150
    Mileage : 150000
    Default whine from front passenger side
    Hi all
    I have had a whine start on my 1.9 cdti 150 estate. (130k) It started after having front springs replaced and only increases with engine speed from 35-40mph. Any ideas I can easily check before I start spending money with any how2'S
    any help greatly recieved!
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Don't let the wife in the car.
    Seriously though, I take it you have made sure everything was reconnected properly after fitting springs, and that there is nothing rubbing the wheel or tyre. After that I would be checking wheel bearing is ok, though I would expect that to be almost constant. Without seeing the vehicle I can't suggest anything else.
    3.2 v6 Signum and loving it
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Brake sheild been knocked and rubbing against the dics maybe?
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Quote Originally Posted by AntSSSS View Post
    Good shout though when that happened on mine it was constant. Well worthwhile checking though.
    Wiltshire
    Mileage : 150000
    All reconnected fine. Had car and ramps and can't hear wheelbearing grind.
    Will check brakes though.
    Any other ideas? Could it be low gearbox oil?
    Quote Originally Posted by Johnsdutton View Post
    Wiltshire
    Mileage : 150000
    Checkeddisc sheild all fine? anyone else had similar issues with a remedy!!!???
    lincolnshire
    just because you cant hear wheel bearing , dont mean its not cream crackered
    Wiltshire
    Mileage : 150000
    Quote Originally Posted by bembo449 View Post
    ok me being an amatuer mechanic (lol ) hows best to check..... i thought feeling axles after long run to see if run hot would be a check.....
  1. How to fit Front Passenger Side Door glass
    By thehoq in forum Bodywork & Interior
    Last Post: 14th March 2013, 15:59
  2. Play in passenger side front wheel hub!
    By Jow20 in forum Suspension, Wheels & Brakes
    Last Post: 14th February 2013, 14:25
  3. Clunking from Front Passenger Side
    By nick-v2.2 in forum Vectra C / Signum Car Chat
    Last Post: 17th January 2009, 14:19
  4. Noised from Passenger Side Front Mirror, Please Help
    By S14RRJ in forum Suspension, Wheels & Brakes
    Last Post: 7th May 2008, 20:42
  5. Front Passenger Side Brake fire??!!!!
    By VinnyPeewee in forum Suspension, Wheels & Brakes
    Last Post: 6th December 2007, 15:07
