Thread: Door lock 5 pin vs 7 pin connector
    Sep 2009
    south holland
    Default Door lock 5 pin vs 7 pin connector
    Hi,
    Recently my 2003 vectra started to show the door lock problem where the car thinks the door is still open when it is actually closed. Ordered a new driver side door lock but on installation found out it had a different type number. The only difference I could see was that the new door lock has a connector with only 5 pins while the old has 7. Because I needed the car went ahead and installed the door lock mechanism and everything seems to work. Now I just wonder what the additional two pin in the old lock were for?
    Jaap
    Regular Member Kaies_1981's Avatar
    spain
    The 2 Pin on the old lock it's work once you Opel the car with key blade and all door Opel,the new lock only Opel de driver door!!
    Full Member plasma's Avatar
    On the Forum
    346 Post(s)
    Engine : 150
    Mileage : 74000
    probably electrical lock sensor, when you push the button down it locks all the doors, was a feature on the very early models but was deleted to my knowledge
    Sep 2009
    south holland
    Thanks, you were both right.
    Just tried it and indeed when using the key or the mechanical door lock button it now only locks the drivers door. I am not sure if you can still get the locks with this feature but I don't think I will take it all apart again. When you mentioned it I remembered it worked like that but actaully never seem to have used it in normal day to day use. However will let the dealer know they provided me with a wrong part.
    Jaap
    Birmingham
    Sound like my problem, when the door is closed, it thinks it open so when I go to LOCK the doors they flick open again.
    How hard was this door lock to fit?
    Bye bye Vec B
    - Hello Siggy!
  1. For Sale: Speedo / Door Speakers / Door Tweeters & Boot Lock Mechanism
    By Woody in forum Parts for sale
    Last Post: 21st March 2013, 01:15
  2. What method is used to disconnect door connector
    By wickedwillie in forum Electrical & ICE (including SatNav)
    Last Post: 27th November 2012, 13:18
  3. How do u unplug Door switch Connector ???
    By Dal5band in forum Bodywork & Interior
    Last Post: 28th March 2012, 23:19
  4. OSR External Door Handle & OSF Door Lock
    Last Post: 29th May 2009, 17:14
  5. Drivers door window switch connector
    By neilt in forum Electrical & ICE (including SatNav)
    Last Post: 15th November 2008, 21:28
