Results 1 to 3 of 3
Thread: Water Pump
    Regular Member clightowler's Avatar
    Oct 2007
    Leeds
    Trim : SRI hatch
    Engine : z19dth
    Mileage : 110000
    Default Water Pump
    Changing timing belt and Water pump on my Z19DTH, there are two water pumps listed on EPC one for engines pre 17376047 and the other for engines later than that.
    Have googled the part numbers and some sellers quote the engines pre 1737xxxx but only when fitting to an astra, with no mention of engine numbers for the Vec C.
    Does ayone know if there is a difference between the two pumps? my engine no is the 1710xxxx range.
    have ordered belt kit from here:
    http://www.mister-auto.co.uk/en/timi...1CT1105K1.html and they have asked for original part number of water pump to ensure that they send correct one.
    Barrow In Furness, Cumbria
    Probably best asking Vauxhall dealer.
    Oct 2009
    Luton
    Change was in 2008...new version has reinforced bearing (roller-ball instead ball-ball).
    Yours will be the early type 93179114 which superseeds to 93191762.
  1. water pump
    By GCusdin in forum Engine & Drivetrain
    Last Post: 7th March 2013, 21:16
  2. Water pump.
    By Kenny_Exclusiv in forum Engine & Drivetrain
    Last Post: 24th September 2012, 22:19
  3. New water pump due???
    By R33Leroy in forum Engine & Drivetrain
    Last Post: 1st April 2012, 21:27
  4. Water pump
    By FRANKA in forum Vectra C / Signum Car Chat
    Last Post: 31st March 2010, 18:55
  5. Water Pump 2.2
    By richpu in forum Engine & Drivetrain
    Last Post: 27th January 2009, 01:46
